Author Topic: 1198 depth reading problems  (Read 17068 times)
Offline Knock
  • Unit(s): 1198/999
« on: May 10, 2015, 01:50:31 PM »
Having trouble getting depth readings at idle and at WOT.  Usually just shows .6'.  I am currently running an 1198 at consol linked with a 999 up front.  I have the splitter on the 1198 running to standard 2d transducer shoot through and the HD transducer on transom.
Re: 1198 depth reading problems
« Reply #1 on: May 10, 2015, 07:59:56 PM »
You could be getting electrical interference.
That can affect the depth reading.
Go to an area with known depths and shut off everything except your sonar.
Drift around and see if the depth reads OK.
If it does, then it's electrical interference.
Secondly: with your boat in the water and fully loaded, your transducer
should be more or less even/level.
« Reply #2 on: May 10, 2015, 10:35:01 PM »
In addition to what ITGEEK mentioned ...
You might try disconnecting the AS SIDB Y cable and plug the HDSI directly into the head unit ...
If the depth issue is fixed ... The AS SIDB Y cable is bad, the shoot thru xducer is bad, or the shoot thru installation has failed ...
If the depth issue is still present with only the HDSI connected ... The head unit may need to be sent to HB ...
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
« Reply #3 on: May 11, 2015, 10:24:28 AM »
Make sure you have the proper 2D transducer selected on the network. Bob
Offline Knock
  • Unit(s): 1198/999
« Reply #4 on: May 11, 2015, 11:34:10 AM »
Thanks for the responses...be the weekend before I can get back on the water to try them out.  I'll let y'all know what I find out
Offline Knock
  • Unit(s): 1198/999
« Reply #5 on: June 01, 2015, 09:04:08 AM »
Finally got a chance to get back on the water this weekend.  After a more thorough test I found that anytime I reach deep water...say 20'+...I'll loose signal on my 2d and on down image and depth along with it.  What I don't get is I never loose side image.  The linked 999 up front never looses anything.  I checked all the connections at y-splitter, at unit and battery (which is new) and all are good.  Any ideas?
Offline bobcoy
« Reply #6 on: June 01, 2015, 09:35:21 AM »
Did you do as Rickie suggested? If you don't find out if your "Y" cable shoot through connection is good you can't diagnose your problem. A crappy transducer signal through the hull  or bad "Y" cable will cause exactly what you describe. You say you loose your 2d signal do you mean the digital reading or the image of the bottom you have on your screen? Your down image and SI both come from the same source. Where is the bow units transducer that keeps working? Maybe start with resetting to default values to eliminate the possibility of settings causing your problems.
Offline Knock
  • Unit(s): 1198/999
« Reply #7 on: June 01, 2015, 10:03:43 AM »
Copy...I'll reset defaults and disconnect splitter next time I'm on the water....the loss of 2d is in depth and sonar reading on screen.  This all happens simultaneously with the drop of down image.  The bow unit transducer is located on the trolling motor.
Offline bobcoy
« Reply #8 on: June 01, 2015, 10:38:43 AM »
Another option might be selecting the transducer from the bow for the console unit for diagnosis but first find out if your shoot through is the curprit or not. A guess of a puck jarred loose or gone bad is my bet. Bob
Offline Knock
  • Unit(s): 1198/999
« Reply #9 on: June 06, 2015, 02:55:21 PM »
Question...2d transducer was installed with clear silicone.  Could that affect readings?
Offline bobcoy
« Reply #10 on: June 06, 2015, 05:46:32 PM »
Yes, that stuff absorbs the sound. Very bad idea but easy to remove and epoxy it back down. SLOW CURE EPOXY only. Bob
« Reply #11 on: June 06, 2015, 06:18:08 PM »
What bobcoy said
Last post June 23, 2010, 09:24:55 PM
by reelman
Last post June 11, 2010, 08:42:41 PM
by majflyboy
Last post August 19, 2011, 01:50:51 AM
Last post October 31, 2012, 03:42:56 PM
Last post May 07, 2014, 10:28:16 AM
Last post May 29, 2014, 08:41:20 AM
Last post July 28, 2014, 12:32:18 PM
Last post February 16, 2015, 12:26:34 PM
by jworks
