Author Topic: SHP import get an error  (Read 16260 times)
Offline varimas
  • Unit(s): Humminbird 899siHD
  • Software: 899ciHD_SI_v7_650
  • Accessories: HumminbirdPC 4.4.6
« on: May 16, 2016, 12:55:18 PM »
Why when doing imports from the vector format (shp files line standard) always after converting AutoChartPro introduces additional false points? Maybe it's AutoChartPro software error? See in the pictures.
« Last Edit: May 16, 2016, 12:56:37 PM by varimas »
Offline CamoHunter
Re: SHP import get an error
« Reply #1 on: May 16, 2016, 01:00:58 PM »
Looks to me like different coordinate systems are being used.  Not sure what coordinate system you're using in ArcMap.
Try drawing a shoreline .kml in Google Earth, and import that into AutoChart.
Not sure what coordinate system is used in AutoChart, but most marine depthfinders use WGS84.
Offline varimas
« Reply #2 on: May 16, 2016, 01:22:37 PM »
The coordinate system is good WGS84, if imorted coordinates was not WGS84 - AutoChart software not recognize imported file. Get an error: "DATA NOT FOUND".
Later, I'll export this shp file to klm. As i remember before Google Earth show exported file good.
Offline varimas
« Reply #3 on: May 16, 2016, 03:18:58 PM »
This is exported shp file to Google Earth (its a same WGS84 coordinates as get AutoChartPRO).
As you see no one false point or line.
Offline varimas
« Reply #4 on: May 16, 2016, 04:00:33 PM »
Hi All.
Problem was solved.
It's my mistake: when importing shp vector standard files in AutoChart we must remove selection on "Import Settings" -> "Apply Track Smoothing" . (See on the picture).
Now AutoChart import shp files without error.
Last post July 11, 2010, 08:27:24 PM
Last post March 29, 2012, 11:13:01 AM
by MichBill
Last post August 07, 2012, 01:25:31 PM
Last post April 28, 2014, 08:11:49 PM
by D S
Last post September 07, 2015, 07:04:07 PM
by LittleGazoo
Last post September 12, 2015, 08:54:30 PM
by lancepeterson
Last post July 09, 2016, 07:16:33 AM
by flamesay
Last post January 02, 2024, 07:49:10 PM
