Author Topic: Import waypoints SD  (Read 31308 times)
Offline flamesay
  • Unit(s): matrix 97
  • Accessories: Combo
Import waypoints SD
« on: June 21, 2016, 06:20:38 AM »
Hello friends,
I recently bought my matrix97 and would like to insert waypoints.
Before he used OpenCPN and garmin homeport, so I have my waypoints in *.gpx, *.wpt and *.gdb
Is it possible by SD card have my waypoints in the matrix?
I tried to insert with the software HumminbirdPC but when I insert the card into the GPS does not show anything.
Re: Import waypoints SD
« Reply #1 on: June 21, 2016, 09:46:51 PM »
If you imported your Waypoints into HBPC and allowed HBPC to put the Waypoints into the SD Card ... HBPC should have created the Matrix folder on the SD Card ...
Can you open the SD Card on your PC to see if the Matrix folder is actually on the SD Card ... ??
Offline flamesay
« Reply #2 on: June 27, 2016, 10:24:22 AM »
Yes, the folder and the file is inside. But when I enter the SD in GPS no option to import waypoints appears. I do not know what to do
« Reply #3 on: June 28, 2016, 09:20:34 AM »
Try inserting the SD Card (with the Nav data) into the unit before powering on the unit ...
Your unit may have old enough software to need this sequence to recognize the command ...
Offline flamesay
« Reply #4 on: June 30, 2016, 07:01:47 PM »
I inserted waypoints using the software, I tried turning on the matrix and then insert the card and does not show me any message or option.  ???
« Reply #5 on: July 01, 2016, 10:59:24 PM »
I think I'm understanding that the unit was powered on ...and then the SD Card was inserted ...
Try inserting the SD Card and then power on the unit ...
Offline flamesay
« Reply #6 on: July 03, 2016, 04:02:20 PM »
I tried both options and it doesn't work. I have firmware version 2.450
« Reply #7 on: July 03, 2016, 11:00:20 PM »
Are you using a SD Card or a SDHC card ...??
That old of software would need to use a SD Card ... Not a SDHC ...
Software to enable reading the SDHC type SD Cards was not until much later than your version ...
« Last Edit: July 03, 2016, 11:01:34 PM by rnvinc »
Offline flamesay
« Reply #8 on: July 04, 2016, 04:53:48 AM »
I'm using a 32mb SD card, which have the charts.
Would be possible to upgrade by sd card? maybe the problem?
« Reply #9 on: July 05, 2016, 10:09:02 PM »
I think there was a max size SD Card needed for units running older software ...
Can you find a regular SD Card (not SDHC) in 8gb or less ... ??
Offline flamesay
« Reply #10 on: July 06, 2016, 05:29:32 PM »
Yes, I could find it. But waypoints to install or to update the software?
« Last Edit: July 06, 2016, 11:26:30 PM by rnvinc »
« Reply #11 on: July 06, 2016, 11:26:59 PM »
Try a smaller SD Card for importing Waypoints ...
Offline flamesay
« Reply #12 on: July 09, 2016, 07:16:33 AM »
I tried with a 64mb SD and still do not see anything. Waypoints file occupies 100kb, I do not think space is the problem.
If I update it is possible that the problem is corrected? Is there any changelog versions?
Last post April 06, 2012, 04:49:19 PM
Last post June 10, 2013, 12:04:02 PM
Last post April 28, 2014, 08:11:49 PM
by D S
Last post September 07, 2015, 07:04:07 PM
by LittleGazoo
Last post September 12, 2015, 08:54:30 PM
by lancepeterson
Last post May 16, 2016, 04:00:33 PM
by varimas
Last post December 10, 2016, 04:28:15 PM
by jimham82
Last post January 02, 2024, 07:49:10 PM
