Author Topic: Using another unit as a remote monitor  (Read 11505 times)
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« on: May 15, 2016, 01:20:58 PM »
I am not knowledgeable about networking. Heed your help.  I have two 1199's. If I purchase 2-- AS EC QDE's plus one-- AS EC (to length) E cable and hook the two units together and supply power to the second unit, will it function as a monitor and show what I'm looking at on the main unit? The second unit will not be attached to a transducer.
             Mike
Re: Using another unit as a remote monitor
« Reply #1 on: May 15, 2016, 04:53:49 PM »
Yes .... If there is no transducer connected to the one unit, it is best to turn off the sonar on it.
The transducer sharing is located in the Network Setup menu....you can share the 2D, SI, and GPS from one unit to the other.
« Last Edit: May 15, 2016, 05:15:47 PM by sonar2000 »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: May 15, 2016, 05:05:30 PM »
Thanks Bob
      Mike
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #3 on: May 19, 2016, 09:12:38 PM »
Not ONLY is it best to turn off the slave unit's Sonar - it will damage the unconnected unit, if you don't - and that's not warrantied either.
Seen it happen to peeps.
 :o
One of my 999's has been running this whole past season with nothing but the AS EC QDE and the PC11 connecting the unit - I take the 2D off the front trolling or whatever I put up on the Port side 999 while under way - I'll put something with map in front of me.
You'll like the options if you decide to mount a XDCR on both ends.
Even if your don't ~ enjoy, it's great stuff.
« Last Edit: May 19, 2016, 09:15:29 PM by sfw1960 »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #4 on: May 19, 2016, 11:59:35 PM »
Thanks for reminding about shutting off the sonar.
        Mike
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #5 on: May 20, 2016, 12:25:02 PM »
Part 2 of the question.
   Can the person viewing the second (slave) unit adjust the settings / views without affecting the main unit?
          Mike
Offline sfw1960
« Reply #6 on: May 20, 2016, 12:32:21 PM »
NO.
The controls on the slave  act as if they are the master unit's.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #7 on: May 20, 2016, 03:20:52 PM »
Thanks for the reply. The three cables are around $125.00  Just trying to figure if it's worth it for my rider.
         Mike
Offline sfw1960
« Reply #8 on: May 20, 2016, 03:49:57 PM »
I would buy from  James Metz (Ext 706) @Universal Mania - tell him Robert sent you & ask if he can work you a deal !
 ;D
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #9 on: May 20, 2016, 03:58:32 PM »
Last post January 30, 2011, 02:20:17 PM
Last post March 23, 2011, 09:48:19 AM
by haggy38
Last post October 29, 2012, 07:26:17 PM
by Gator
Last post December 02, 2012, 03:48:13 AM
by mako101
Last post May 28, 2013, 11:43:49 AM
Last post May 11, 2015, 05:03:39 PM
by RonnieB
Last post June 04, 2017, 12:05:21 AM
Last post May 03, 2020, 07:08:44 PM
by Dave Sutton
