Author Topic: extra monitor  (Read 9697 times)
Offline Gator
    • Crappie Club Page
  • Unit(s): 1198 c si, (2)998c si, 798ci HD si
  • Software: top secret
  • Accessories: ethernet, weather sence, I Pilot Link
extra monitor
« on: October 26, 2012, 07:01:31 PM »
I have a 998c SI installed on my console, can you buy somthing in the 800 series without a transducer that i could link to my 998? To mount on my bow...
Offline Gator
    • Crappie Club Page
Re: extra monitor
« Reply #1 on: October 26, 2012, 07:24:47 PM »
i would like to share the transom mounted SI transducer between the units and hook up the US2 in my terrova to the bow mounted unit. is this possible?
Re: extra monitor
« Reply #2 on: October 29, 2012, 12:49:14 PM »
Yes you could.
Depending on what sonar you want to share will dictate which 800 series unit you will have to purchase:
 - If you want the Si and or Di sonar from the transom mounted HDSi transducer up front; your only choice is the 898c Si unit.  Be sure to set the Transducer Select/Connected Transducer menu to the “Universal Sonar 2” setting when using the Terrova’s transducer and back again to the “Hi-Def Sidescan” setting when using the sonar data from the 898c Si unit.
 - If you only want the 2D sonar from the transom mounted HDSi transducer up front; you will need the 858c model unit.
To buy a unit minus the transducer, you need to look for a “CHO” designated unit (Example: “898c Si CHO”).
Offline George
  • Software: Always up todate
Re: extra monitor
« Reply #3 on: October 29, 2012, 02:36:09 PM »
Greg
If Gator links to his 998, will he be able to view the Navionics map from his 998?  I am guessing that he will only be able to view everything else.
George
Re: extra monitor
« Reply #4 on: October 29, 2012, 04:15:56 PM »
No George, mapping data cannot be shared between units.
Offline Gator
    • Crappie Club Page
Re: extra monitor
« Reply #5 on: October 29, 2012, 07:26:17 PM »
Thank you Greg.
Last post May 12, 2010, 08:34:39 PM
by calli1
Last post January 30, 2011, 02:20:17 PM
Last post March 23, 2011, 09:48:19 AM
by haggy38
Last post February 05, 2012, 09:56:41 AM
Last post April 22, 2012, 01:03:24 PM
Last post May 20, 2016, 03:58:32 PM
Last post June 04, 2017, 12:05:21 AM
Last post May 03, 2020, 07:08:44 PM
by Dave Sutton
