Author Topic: Humminbird Weather Sense™ Monitor  (Read 17262 times)
Offline haggy38
  • Unit(s): 898c SI
  • Software: 5.210
  • Accessories: Weathersense
« on: March 21, 2011, 03:54:46 PM »
Hi Guys, I bought  the Humminbird Weather Sense™ Monitor for my 898C SI unit, and is not working well, as soon I turn on my unit it says in connected and in 5,10,30 minutes it says disconnected, then connected and then disconnected again in different timing, The connections are good and don't know what to do, hope you can help. :-[
Regards,
Gustavo Fernandez Johnson
Re: Humminbird Weather Sense™ Monitor
« Reply #1 on: March 21, 2011, 07:42:35 PM »
Is it working when it is connected??
chuck
Offline haggy38
  • Unit(s): 898c SI
  • Software: 5.210
« Reply #2 on: March 21, 2011, 11:34:48 PM »
Hi Chuck, it's intermittent between connected and disconnected in different timing , is this normal?
Regards,
Gustavo
« Reply #3 on: March 22, 2011, 10:21:54 AM »
This is not normal.
Could something be blocking the receiver for WXS. Sometimes it is and sometimes it is not.  Where is the receiver located...
Offline raricker
  • Unit(s): 797c, 998c
  • Software: 5.450, 6.490
  • Accessories: weathersense, aux speed,GRHA
« Reply #4 on: March 22, 2011, 12:25:12 PM »
Hi,
You might want to try changing the Weather Sense Module battery (I believe it is a 2032 disc - you have to take the back cover off the unit to change it) and see if that helps.
Take care,
Roger
« Reply #5 on: March 22, 2011, 12:54:58 PM »
Does anyone know the satelite number for Wx Sense signal?  Or how many satelites provide the XM information.
« Reply #6 on: March 22, 2011, 02:53:09 PM »
I think there is some confusion here.
'Weather Sense' is just a barometric pressure reading device that you buy once and hook up to your system and there are no further charges.  It does not use any Satellites.
'XM Sirius Weather' is what uses the Weather satellites, which has a monthly service charge.  You have to purchase the XM weather module, plug it into your system, and contact Sirius to activate it.
If you are talking about 'Weather Sense', then I agree that you should check the battery in the device.
« Last Edit: March 22, 2011, 02:56:44 PM by ITGEEK »
Offline haggy38
  • Unit(s): 898c SI
  • Software: 5.210
« Reply #7 on: March 22, 2011, 03:30:23 PM »
The manual says CR2450 or equivalent, it suppose to be installed shielded from direct sunlight, I don't think it connects to any satellite right?
This is my unit.
Regards,
Gustavo
« Reply #8 on: March 22, 2011, 04:52:08 PM »
ok...I probably did not read your post correctly.
Let me look around a bit more....
« Reply #9 on: March 22, 2011, 04:58:01 PM »
ok....if you are speaking of the AS BP  then the battery may be low as indicated...try that first.....
« Reply #10 on: March 23, 2011, 07:51:33 AM »
Yes Gustavo,
You are correct.  It does not use any satellites.
It only reads local (i.e. - where it is physically located) barometric pressure.
You have to spend more money to use satellites. :)
« Last Edit: March 23, 2011, 07:57:26 AM by ITGEEK »
Offline haggy38
  • Unit(s): 898c SI
  • Software: 5.210
« Reply #11 on: March 23, 2011, 09:48:19 AM »
Thanks guys, I will try to change the battery.
Regards,
Gustavo
Last post May 07, 2009, 01:20:18 PM
Last post May 03, 2010, 02:17:11 AM
Last post August 03, 2012, 12:48:54 PM
by Jim Jack
Last post August 01, 2012, 07:15:29 AM
Last post October 29, 2012, 07:26:17 PM
by Gator
Last post May 20, 2016, 03:58:32 PM
Last post June 04, 2017, 12:05:21 AM
Last post May 03, 2020, 07:08:44 PM
by Dave Sutton
