Author Topic: 899 800KHz SI washout issue question  (Read 9707 times)
Offline lock1nout
  • Unit(s): 899ci HDSI
« on: May 04, 2016, 01:58:06 PM »
I thought I would ask here before trying to resurrect on old thread regarding the 899 800KHz SI washout issue. http://forums.sideimagingsoft.com/index.php?topic=7642.msg46390#msg46390
Was this issue ever solved via software update? I believe I also have the washout look, but haven't used the unit since '14 and want to take advantage of my extended warranty to fix this issue if it is a hardware only fix. I have not kept current with all the latest software updates since then. I have the 2014 899CI HDSI model.
Re: 899 800KHz SI washout issue question
« Reply #1 on: May 04, 2016, 04:22:42 PM »
The washout issue was identified and fixed ...
Units that were already shipped with the washout issue must be sent back to HB for the hardware fix ...
Call HB with your serial number ...as they have a list of the serial numbers affected ...
1-800-633-1468
Offline lock1nout
« Reply #2 on: May 05, 2016, 02:50:04 PM »
Thanks. Just called HB. Service had no recollection of any affected serial number list. Regardless, my issue is being sorted out.
Last post September 19, 2013, 09:34:28 AM
by Rickard
Last post December 01, 2014, 10:06:07 PM
by sfw1960
Last post September 24, 2014, 06:38:37 AM
by bgump24
Last post December 29, 2015, 12:04:30 AM
by sfw1960
Last post April 09, 2015, 01:47:55 PM
by sean55337
Last post July 25, 2015, 09:32:10 PM
by Notchyfl
Last post June 10, 2015, 01:05:26 PM
Last post November 12, 2015, 06:34:58 AM
by JoeyWelch
