Author Topic: Just got my 999ci - question/issue  (Read 11311 times)
Offline aucivil
  • Unit(s): 999ci SI Combo
  • Accessories: I-Pilot Link - Minn Kota Ulterra
« on: June 06, 2015, 11:27:57 PM »
mounted the transducer on a board to test a location before I mounted it permanently.  Worked great even at speed (with some noise).  Did notice that in SI mode the left side looked like an image on the moon in full sun (bright) while the right side was darker and had better detail.
Does this sound like a mounting issue, transducer issue or head issue?
TIA
Re: Just got my 999ci - question/issue
« Reply #1 on: June 06, 2015, 11:41:21 PM »
I would eliminate any mounting issues first.
For SI, the transducer needs a clear line of site to both sites.
Could your main motor be blocking all or part of the signal going to the left?
Also, if your hull has rivets, the water coming off rivets could be aerated.
Could that be happening to the left side of the transducer?
« Reply #2 on: June 07, 2015, 01:10:12 AM »
Determine if the image on the left is still blocked when just drifting ..... If it is, trim the motor up and see if it goes away.
Offline aucivil
« Reply #3 on: June 07, 2015, 01:16:32 PM »
Will be a few weeks before I can take her out again but will give ideas a try.  I did have the motor trimmed and visually the transducer looked clear.  Had it mounted below everything at the high speed waterline.  It's a Triton sf21.
Offline badaxed
  • Unit(s): 999 ci is, helix 8si g4n, helix 8di g4n
  • Software: 7.460 for 999 si hd
  • Accessories: GPS puck,
« Reply #4 on: July 15, 2015, 11:17:22 PM »
Same thing with me. Did a reset and improved.
Fishing: lots of run, sun, fun, catch a ton or didn't get none.
Offline Notchyfl
  • Unit(s): 999 si
  • Software: 7.650
« Reply #5 on: July 25, 2015, 09:32:10 PM »
Maybe you already know but make sure you mount transducer on correct side in regards to prop rotation. Mounted mine where old transducer had been, did not work.
Last post February 14, 2014, 12:57:39 PM
Last post June 29, 2014, 03:25:36 PM
Last post February 27, 2015, 08:42:43 PM
Last post December 03, 2015, 09:27:06 AM
by Boots
Last post May 05, 2016, 02:50:04 PM
by lock1nout
Last post May 10, 2016, 07:33:21 PM
Last post June 27, 2016, 08:49:01 AM
Last post September 27, 2022, 06:22:03 PM
