Author Topic: 899 blurry SI on 800khz need solution  (Read 10529 times)
Offline bgump24
  • Unit(s): 899 SI
« on: September 23, 2014, 09:11:41 AM »
my SI has good view on 455 kHz but when I switch to 800 kHz its really bright and blurry cant make out anything what is the solution
Re: 899 blurry SI on 800khz need solution
« Reply #1 on: September 23, 2014, 09:23:51 AM »
First off; what is the model name of the transducer you are using with the 899 unit?  Are you using the Compact Side Imaging (CSi – XNT-9-Si-180-T) transducer that came with the 899 unit or did you exchange it for the larger High Definition Side Imaging (HDSi – XHS-9-HDSi-180-T) transducer?
Is this a new problem or has it always been like this?
Offline bgump24
  • Unit(s): 899 SI
« Reply #2 on: September 23, 2014, 10:03:15 AM »
I exchanged for the high def
« Reply #3 on: September 23, 2014, 12:04:03 PM »
Than you should contact the Humminbird Customer Resource Center folks about this.
Offline bgump24
  • Unit(s): 899 SI
« Reply #4 on: September 24, 2014, 06:38:37 AM »
I did got all the info to send it back and have it repaired
Last post October 25, 2010, 04:45:49 PM
by abraquelebout
Last post April 04, 2012, 11:37:06 AM
Last post October 15, 2012, 04:34:35 PM
Last post September 19, 2013, 09:34:28 AM
by Rickard
Last post May 23, 2014, 11:28:41 PM
by rsouza3
Last post December 01, 2014, 10:06:07 PM
Last post December 29, 2015, 12:04:30 AM
Last post August 06, 2018, 04:22:02 PM
