Author Topic: 998c Transducer showing Not Connected on power up  (Read 17308 times)
Offline Bassman13579
  • Unit(s): 998c SI
« on: March 13, 2016, 05:12:47 PM »
When I power up unit I get a TRANSDUCER NOT CONNECTED message.
Sometimes I can run the boat a little and the unit will power up find ?
Sounds like loose connection maybe ? I'm not sure
I would appreciate any help on this problem.
Re: 998c Transducer showing Not Connected on power up
« Reply #1 on: March 13, 2016, 10:11:08 PM »
Bend the pins ever so slightly in the xducer cable connector to try and get a better contact of the pins in the socket ...
Be careful ...the pins break easy ...so don't bend much at all ...
  • Unit(s): 998c SI
« Reply #2 on: March 16, 2016, 08:16:19 PM »
I tried bending pins. No good. Took connector apart that attaches to back of unit. Cables looked good. I was going to put transducer in 5 gallon bucket of water and found transducer was sticking straight up. Took transducer off bracket and put in top of bucket of water and turned unit on. Same message Transducer not Connected. Could sensor being straight up give me this message ? Is there away of ohming out transducer pins that would tell me if cable is good ?
« Reply #3 on: March 16, 2016, 11:22:05 PM »
I'm not understanding "sticking straight up" ...do you mean the xducer was vertical in the mounting bracket like it may have hit something in the water ..??
  • Unit(s): 998c SI
« Reply #4 on: March 17, 2016, 12:01:22 AM »
Yes the transducer was vertical like it hit something. I fish a lake that has stumps around the banks
I will be fishing and the boat will get hung on a stump and I will have to back up to get boat dislodged from stump.
« Reply #5 on: March 18, 2016, 03:43:41 AM »
Can you see any damage to the xducer or the cable ... ??
  • Unit(s): 998c SI
« Reply #6 on: March 19, 2016, 11:56:44 AM »
No damage on either
« Reply #7 on: March 19, 2016, 11:41:30 PM »
You can try crosstesting with another head unit or another xducer if you have access to either one ...
If you don't have access to either call HB ...
1-800-633-1468
  • Unit(s): 998c SI
« Reply #8 on: March 20, 2016, 09:55:10 AM »
I appreciate your help RNVINC.
To test with another transducer it would have to be compatible for a 998c unit correct ?
I have two black/white gps hummingbird finders. One in the drivers console and the other on the front deck used on the trolling motor.
« Last Edit: March 20, 2016, 11:32:17 PM by rnvinc »
« Reply #9 on: March 20, 2016, 11:31:41 PM »
You can test xducer connection with any HB xducer that has the "house shaped" xducer cable connector end ...
« Last Edit: March 20, 2016, 11:33:44 PM by rnvinc »
  • Unit(s): 998c SI
« Reply #10 on: March 21, 2016, 01:57:12 PM »
I disconnected cables off of the HB unit on the front deck and connected to my 998c unit. Pressed on and the unit started up and gave me the same message Transducer not Connected. So we can eliminate the Tranducer cable being bad on the 998c unit. Problem is in the unit itself.
  • Unit(s): 998c SI
« Reply #11 on: March 22, 2016, 11:28:41 AM »
UPDATE
I wanted to download all my waypoints onto a card so they would not be lost. Carried unit out to boat and just plugged the cables into the back of unit. I didn't tighten up thumb screw for the cable unit I just pushed cable unit into the back of unit. I inserted card and pushed the on button and yes you guessed it the 998 powered up with no messages. The unit was reading the transducer ?
I tried many configurations, back up card in/out, tightened thumb screw down/ loose, mounted on ram mount/ off of mount etc..  I couldn't get the unit to not start up with a fault message. Unit works find ? Now I know this want last but only thing I can figure is there is a loose connection somewhere ? Just don't want to pay a $380 repair fee for a loose connection (Per HB repair site).
« Reply #12 on: March 22, 2016, 11:56:18 PM »
Sounds definitely like a connection issue ...
You can try bending the pins more ... Just be careful with them ...
  • Unit(s): 998c SI
« Reply #13 on: March 25, 2016, 10:04:24 PM »
Update: Ordered a new transducer and the 998c unit works find now.
Thanks for all the help.
Last post December 20, 2010, 10:21:35 AM
Last post January 08, 2011, 02:16:42 PM
Last post August 13, 2011, 06:07:53 AM
by ericmx
Last post March 18, 2013, 09:03:57 AM
by Jim Jack
Last post December 25, 2013, 11:15:49 PM
by slabbacks
Last post July 16, 2015, 05:09:44 PM
by Silkwood
Last post June 06, 2017, 10:02:20 AM
by bfischer62
Last post April 14, 2019, 08:59:43 PM
