Author Topic: O.K. to power up without gps or transducer.  (Read 7491 times)
Offline RPJ
« on: January 08, 2011, 11:50:38 AM »
Is it o.k.  to power up all of the units using a PC10 cable and without the GPS puck and transducers from the comfort of my sofa. I have a rechargable 12v battery like a gel cell that I can use.
Re: O.K. to power up without gps or transducer.
« Reply #1 on: January 08, 2011, 12:20:59 PM »
RPJ,
Welcome to the forum.  Yes, it is fine to power up without the GPS or Transducer plugged in.
Good Luck,
Wayne P.
  • Guest
« Reply #2 on: January 08, 2011, 12:21:30 PM »
Yes, I have two units hooked to a 12V power source in my den.
Use the Simulator to practice with it.
« Reply #3 on: January 08, 2011, 02:16:42 PM »
It will be fine unless you have a transducer cable extender plugged in.
If this is the case you could fry (burn up) the transmitter in the unit if you power on without the actual transduvcer attached.....
Last post June 16, 2010, 05:41:17 PM
by depark1
Last post March 25, 2016, 10:04:24 PM
by Bassman13579
Last post March 22, 2018, 04:03:54 AM
by barfoot
Last post April 17, 2019, 09:23:55 PM
