Author Topic: Recordings on the SD card  (Read 10976 times)
« on: March 17, 2010, 12:46:22 PM »
I have several recordings on my SD card.....
I frequently take the SD card out of the 1197 to work with the recordings on my pc....HB PC, Humviewer, etc.....
When I get ready to put the SD card back in the 1197 unit......does it matter if the unit is on or off....??
Re: Recordings on the SD card
« Reply #1 on: March 17, 2010, 02:01:26 PM »
Should not make a difference unless you have added a software change.  if all you do is to copy over to your pc then it will be fine to insert with power off.  or if you forget you can put it in with power on.  If you add old files like recordings or snapshots  it will be ok also.  chuck
by slabbandit
Last post May 10, 2013, 03:04:44 PM
by matt@reefmaster
Last post August 07, 2013, 08:46:42 PM
by Fay
Last post October 24, 2013, 09:55:58 PM
by Clackerbuzz
Last post February 10, 2015, 03:11:54 AM
by peterv6i
Last post June 06, 2015, 01:17:27 PM
by CamoHunter
Last post March 26, 2022, 03:42:39 AM
by MT
Last post April 05, 2022, 09:26:37 PM
