Author Topic: Name recordings for HumViewer  (Read 17628 times)
Offline Fay
  • Retirement is the best job I've ever had so far.
  • Unit(s): 798combo, TCR ID-1
  • Software: 7.12
« on: August 04, 2013, 09:40:19 AM »
Where is the best place to rename recordings for view in HumViewer? Now that they are on my pc, how do
I change the names for later viewing?  I've done it before but sure having trouble now.   ???  thanks - Fay
Re: Name recordings for HumViewer
« Reply #1 on: August 05, 2013, 08:56:29 PM »
Fay, put the files in a folder that you have decided a specific name upon.  The folder can be a lake name and subfolders can be dates.
Offline Fay
  • Software: 7.12
« Reply #2 on: August 07, 2013, 11:49:08 AM »
Thanks Chuck, if I have 3 or 4 recordings in the same file I would like to name the places I took them.
I figured out how to do it last summer but since then I must have had a brain fart because I can't figure
out how the heck I got the files and sub-files to carry the same name.  Some of the artificial reefs I fish
in the Chesapeake Bay are broken up into different piles of structure.  Fay
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #3 on: August 07, 2013, 12:30:41 PM »
Use Windows Explorer(not Internet Explorer).
Right-click on the folder(or file), then select Rename.
« Reply #4 on: August 07, 2013, 06:51:01 PM »
If you have a recording file and then multiple recording in the "RECORD" You can move each recording into its own subfile.
That is the .Dat file and the associated record. For example you might have an R000018.dat and the associated record R000018 containing the 6 sonar files. Just copy them over to a file you want named with something you recognize.
« Last Edit: August 07, 2013, 06:53:58 PM by sonar2000 »
Offline Fay
  • Software: 7.12
« Reply #5 on: August 07, 2013, 08:46:42 PM »
Thanks, I'll give it another try.  Fay
Last post May 22, 2012, 05:13:20 PM
Last post June 24, 2010, 05:52:52 PM
by pig75
Last post January 30, 2012, 08:15:19 PM
Last post April 08, 2012, 05:18:05 PM
by RickT
Last post January 25, 2013, 11:27:56 PM
by okiedokie
Last post March 12, 2013, 08:38:22 AM
Last post May 10, 2013, 03:04:44 PM
by matt@reefmaster
Last post January 17, 2017, 11:35:15 AM
