Author Topic: Broken transducer cable (gland)  (Read 20864 times)
Offline Kenneth W. Sørensen
  • Unit(s): 1197c SI Combo
  • Software: Version 6.640
  • Accessories: Towfish
« on: February 09, 2016, 02:08:02 PM »
Hi
I just finish my tow fish, unfortunately have a small problem on my transducer.
My transducer cable is damage just above the transducer itself. The cable gland was also damage so I had to remove it.
I am not worried about the cable, as I sure I able to solder it together. My biggest concern is how to seal the transducer so it would not flood the first time I put it back in the water.
Any suggestions on how to approach this?
[ Specified attachment is not available ]
Offline Rüdiger
Re: Broken transducer cable (gland)
« Reply #1 on: February 10, 2016, 04:32:20 AM »
Hi Kenneth
All make good clean, abrade with fine sandpaper and then sealed with a sealant (Sikaflex, Bilthema ect). Here, the sealant generously apply and a cone around the cable forms.
mvh
Rüdiger
Finding is better than losing
« Reply #2 on: March 08, 2016, 02:45:14 PM »
Hi Rüger
Thanks for the reply.
Unfortunately the ground wire was damage and broken off just above the transducer. I manage to grind a hole in the transducer and solder the ground wire back on.
Now to the big question. Is it possible to measure the transducer circuit?
Offline Rüdiger
« Reply #3 on: March 19, 2016, 04:49:54 AM »
Hi Kenneth
For possible measured values of ask best "Rickard".
mvh
Rüdiger
Offline Rickard
« Reply #4 on: March 19, 2016, 05:16:42 PM »
I heard you...
I don't think measuring the circiuts is needed. A damage to the cable should have no effect on the interior of the transducer. Just follow the colors of the wires and reconnect them.
Rickard
Last post October 27, 2009, 02:23:43 PM
by Macca
Last post November 02, 2010, 03:41:08 PM
Last post November 03, 2012, 11:03:11 PM
by Slip
Last post May 30, 2013, 05:14:51 PM
by RBrad
Last post February 19, 2014, 09:20:57 AM
by N9Phil
Last post February 28, 2017, 11:45:29 PM
by Blove WI
Last post July 27, 2017, 05:17:45 AM
by fishreed
Last post September 19, 2022, 06:46:54 AM
by danlaboucane
