Author Topic: SD Card Question  (Read 4546 times)
Offline Rick72704
  • Unit(s): Helix 9 Si GPS
SD Card Question
« on: November 28, 2015, 08:57:09 AM »
I have read throughout the forum that the Sandisk Extreme III card is used/mentioned for use in humminbird finders.  I have not been able to find these locally, so I found them online. When I received the SD card it was not the extreme III but a Sandisk Extreme SDHC UHS-1 card.  My question is will this card work in a Helix 9 SI GPS. What other Sandisk SD cards that should be at local stores (Walmart, Office depot) would work without problems in the Helix?  Thanks
Offline Rick72704
Re: SD Card Question
« Reply #1 on: November 28, 2015, 12:41:58 PM »
A follow-up question would a SDHC card 32 gb SanDisk Ultra work in the Helix as I found them on sale at Sams until 11-30-15 for $12.86 each.
Offline N9Phil
« Reply #2 on: November 28, 2015, 01:58:26 PM »
I would think that your best bet is the  Extreme SDHC UHS-1 card because the specs say that it will write up to 45mbs where the others say that will only write up to 30 megabytes per second.  You should always use a faster write card because there is less chance of slowdown when your unit is writing to the card.   You can do a google search for the various cards an compare their specification info to get the required info you need.
Phil
Offline Rick72704
« Reply #3 on: November 28, 2015, 04:11:30 PM »
Ok I will keep the first one. Thanks for your help.
Last post October 16, 2010, 11:19:57 AM
by jerry b
Last post May 17, 2012, 09:35:58 AM
by koz54
Last post August 11, 2012, 03:27:19 PM
by dubosegriffin
by slabbandit
Last post May 08, 2014, 11:17:24 AM
Last post March 18, 2016, 12:13:07 PM
by rbdavis3591
Last post April 11, 2018, 11:30:36 AM
by Colorado #5
Last post January 27, 2021, 09:39:02 PM
