Author Topic: 858 HD DI. Memory card question  (Read 9316 times)
Offline theflatlander
  • IF your gonna do wrong. Do wrong right.
  • Unit(s): 858c hd di
  • Software: 6.680
« on: May 07, 2014, 03:15:01 PM »
How do I know my snapshots and waypoints are being saved to my memory card? Does this automatically happen when the card is inserted or is there a setting i need to turn on? I have tried to figure it out if there is a setting and I dont see anything so I am just assuming everything automatically saves to it when the memory card is inserted?
thanks for any help
Offline biggs aquaholic
  • Aquaholic
  • Unit(s): Helix 15 mega msi+, Helix 12 mega msi+
  • Accessories: Mega 360,
Re: 858 HD DI. Memory card question
« Reply #1 on: May 07, 2014, 07:08:17 PM »
The snapshot has to be turned on in the unit, then go to the recording screen and hit the menu button and the start recording will show up on your unit , scroll the key pad to start recording. You must have the recording view  selected to be active in your visible menu selection.
Biggs Aquaholic
« Reply #2 on: May 08, 2014, 11:06:56 AM »
As Biggs mentioned...the Snapshot feature has to be enabled under the "Accessories" tab in the main menu system...
Then, when the "Mark" button is pressed...a snapshot will be saved to an inserted SD Card...
At the same "Mark" button press, a waypoint at the GPS antenna's present position will be saved to the internal memory of the unit...
The snapshot can be verified by opening the "Snapshot and Recording" view to see the saved snapshots and recordings...(the Snapshot and Recording view must be made "Visable" under the "Views" tab in the main menu system...and the SD Card that the snapshot was saved to must be in the card slot ...because the unit "reads" snapshots and recordings directly from the SD Card)...
The waypoint created when the snapshot was taken can be verified under the "Navigation" tab in the main menu system under "Waypoints"...
Or the waypoint can be seen on any chart view....
Waypoints in the internal memory of the unit must be "Exported (also under the "Navigation" tab- then down to waypoints) to get them copied from the internal unit memory onto an inserted SD Card....
« Last Edit: May 08, 2014, 11:11:09 AM by rnvinc »
« Reply #3 on: May 08, 2014, 11:17:24 AM »
I'll just add to what has already been stated:
You will know that the Screen Snapshot and waypoint were created as you will see a message on the display of the unit.
Last post June 22, 2009, 01:21:58 AM
by great pappy cat
Last post April 27, 2011, 04:31:04 PM
by Curt - RI
Last post May 21, 2011, 08:44:56 AM
Last post May 29, 2011, 03:29:04 PM
Last post July 17, 2012, 01:52:18 PM
Last post May 17, 2012, 09:35:58 AM
by koz54
Last post April 30, 2013, 09:01:19 AM
by N9Phil
Last post January 07, 2015, 01:03:24 PM
by bigkahuna
