Author Topic: SI interference  (Read 5181 times)
Offline partner
  • Unit(s): 899si
  • Accessories: none
SI interference
« on: October 27, 2015, 02:20:10 PM »
When the TR1 turns the motor left or right it creates interference. Hummingbird call center won't put me thru to a real tec to answer my questions. Maybe someone here knows. It's has to do with the NMEA between the two. If I pull the com cable off the 899 the interference goes away. Both units are hooked up to a separate power source, yet the ground from the tr1 and the ground from the com are hooked together. Could this be the source of the interference? Running out of patience with the Hum help desk!
Re: SI interference
« Reply #1 on: October 27, 2015, 09:22:32 PM »
Do you mean "Ethernet" instead of NMEA ...??
And I'm confused of "ground from the com" ... ??
The positive and negative for the HB units should be completely separated from any TM wires ...
Even a common on board charger can bleed RFI from the TM system into the HB unit power system ...
« Last Edit: October 27, 2015, 09:25:07 PM by rnvinc »
Last post February 08, 2013, 02:12:20 PM
by Ken L
Last post April 29, 2013, 06:31:32 PM
by Lsobo21
Last post May 13, 2013, 11:20:11 AM
Last post April 10, 2014, 12:49:21 PM
Last post April 27, 2016, 12:30:10 AM
Last post September 16, 2016, 10:28:31 PM
by mike fish
Last post June 05, 2017, 05:02:15 PM
Last post September 15, 2020, 08:58:00 PM
