Author Topic: Left Side Scan Issue...  (Read 7596 times)
Offline joe20toon
  • joe20toon
  • Unit(s): Helix 7 SI
« on: October 26, 2015, 10:54:55 AM »
I just got the Helix 7 and the left side does not show up as well as the right.
I have a 20 foot pontoon boat. Would the left pontoon cause decreased sensitivity?
The engine is not blocking the transducer and I wouldn't think the left pontoon would interfere with it.
The transducer is level. The transducer is on the right pontoon. There's a water pump for the livewells on the
left pontoon. The transducer is lower than the water pump pick up housing.
New to SI
Offline born 2 fish
  • Unit(s): 1199 898
  • Software: 7.460/6.49
  • Accessories: I-PILOT LINK
Re: Left Side Scan Issue...
« Reply #1 on: October 26, 2015, 07:59:26 PM »
It looks to be turbulent water air bubbles coming from a pontoon or something on the back of the boat if you look at your pics the last one looks good you were @ 3 mph when you took that pic.when your going faster bubbles are blocking the si sonar pulse on the left side. Try to keep your boat speed @3 mph as well as your chart speed.see if that helps
Offline mako9man2
  • Unit(s): 999ci HD SI
« Reply #2 on: October 26, 2015, 08:40:55 PM »
Speed is the issue for me.  At 5mph I get a poor SideImage.  At 3.8mph it is perfect.  I know its turbulence from my hull.  My transducer is positioned in the optimal location for my boat.  The only other solution would be to mount the big transducer on a pole and lower it below the level of the hull but I'd forget to raise it and probably drag it off.
« Reply #3 on: October 26, 2015, 09:42:04 PM »
Because of the beam form shape of the SI pulse ...the left pontoon is most likely blocking some of the pulse ...
Pontoons benefit from a dual SI xducer setup with the AS SILR Y cable ...
http://www.humminbird.com/Products/AS-SILR-Y/
Offline born 2 fish
  • Unit(s): 1199 898
« Reply #4 on: October 26, 2015, 11:15:28 PM »
You can always put a si transducer on the left pontoon and the right pontoon using a AS-SILR-Y cable than you will not have a problem. This is what I did and it works great.
Offline joe20toon
  • joe20toon
« Reply #5 on: November 01, 2015, 04:53:54 PM »
Thanks all for the help. I slowed down to 3mph and it looks good.
New to SI
Last post July 19, 2011, 03:25:08 AM
by Roddy
Last post March 25, 2013, 11:06:36 PM
by Bassgrabber
Last post March 12, 2013, 10:30:15 PM
by autopilot70
Last post June 06, 2013, 06:05:53 PM
by matt 01
Last post September 22, 2015, 07:24:45 PM
by fishermanatr
Last post December 06, 2021, 06:58:25 PM
