Author Topic: left side  (Read 11100 times)
Offline matt 01
  • Just fishing
  • Unit(s): 1198csi
left side
« on: June 03, 2013, 10:29:10 PM »
It not as sharp as right and is there away make better pics
Re: left side
« Reply #1 on: June 04, 2013, 09:02:19 AM »
Hey Matt...welcome to sideimagingsoft...
Your profile says 1198c...
Was the unit at 455kHz or 800kHz...??
Re: left side
« Reply #2 on: June 04, 2013, 10:12:33 AM »
Matt,
Do you have any screen snapshots of what you are seeing?
Is there anything to the left side of the Si transducer that could be blocking some of the left Si sonar?  Post a screen snapshot of what the left and right Si sonar looks like with the SI Range menu set at 20 feet.
Offline matt 01
  • Just fishing
  • Unit(s): 1198csi
Re: left side
« Reply #3 on: June 04, 2013, 09:26:05 PM »
it's on 455 I think had the motor up ::)
Re: left side
« Reply #4 on: June 05, 2013, 09:26:58 AM »
The 800kHz frequency will give a more detailed image.......
Choosing frequency is a trade-off decision based on what particular part of the sonar data you want to see at that specific moment....
The 455kHz frequency will usually be brighter all the way out to the sides of the image...but at the expense of filuzzier overall detail....(good for searching and spotting structure farther out to the sides in the SI image)
The 800kHz frequency will be more detailed overall...but it will be at the expense of rendering the outside left and right edges of the image darker...(good for detailed deciphering of structure details closer to the boat...
Here are some comparison shots I took to visually understand this concept...(all conditions and settings were exactly the same except frequency choice...)
*The left image is the 455kHz ..brighter out to the edges - but fuzzier detail...
*The right image is the 800kHz...more detailed and crisper...but darker out to the edges...
Frequency choices are tools (in 2d/DI/ and SI )....
Use each for what it does best for the task at hand...
Offline matt 01
  • Just fishing
  • Unit(s): 1198csi
Re: left side
« Reply #5 on: June 06, 2013, 06:05:53 PM »
THANK U
Last post August 29, 2013, 08:49:38 AM
by themothaship
Last post April 07, 2014, 03:21:20 PM
Last post April 20, 2014, 03:04:27 PM
by cache22
Last post July 24, 2014, 06:45:48 AM
by PeekRhol
Last post May 15, 2014, 03:46:33 PM
Last post June 17, 2014, 10:21:29 PM
by Time Out
Last post June 21, 2016, 11:33:31 AM
