Author Topic: 997c Side Scan Issue  (Read 16761 times)
Offline jhcreid
  • Unit(s): 997c
  • Accessories: Navionics Premium
« on: July 06, 2011, 11:30:40 AM »
Well, just got the unit installed and I'm a little discouraged.
 :( Issue: Can't see scan on left side, think the motor is blocking scan.
I placed the transducer in the same location as my previous transducer. I bought the unit used, so I downloaded the manual from the website and utilized the mounting template for install. I placed the transducer about mid way from the outdrive to the waterline, right side of outdrive. The bottom right of the stainless bracket is just on the dead rise.
I have the transducer about 1/4 inch below the bottom of the boat, it actually creates its own wake when I’m on plane.
The right side scan is great, very little on the left.
I also had to tilt the head down to get the sonar to read depth, is this common as well?
Hope it's not a transducer re-location issue as I have already plugged the hole through the stern. If you have help, or can suggest other threads, please let me know.  Thanks!
Offline Del
  • Unit(s): 1197 SI
Re: 997c Side Scan Issue
« Reply #1 on: July 06, 2011, 11:55:44 AM »
Welcome to the forum!
Can you, by any chance, add a photo of the mounted transducer ?
And no, to tilt the head down to get depth readings is not common and just sounds strange  ;)
Anyways, congratulations to that nice unit! I'm sure we'll get it running and you will be happy with it soon.
Greetings,
Del
Offline jhcreid
  • Unit(s): 997c
« Reply #2 on: July 06, 2011, 03:45:47 PM »
The boats in the water now... I'll grab the scuba gear and underwater camera and get one posted soon. I saw a picture on this forum that looks very similar to my installaion. I'll post it.. stand-by.. :o
Offline jhcreid
  • Unit(s): 997c
« Reply #3 on: July 07, 2011, 10:39:20 AM »
This is not my boat, but very similar installation. On an inboard/outboard boat, is it common to have to use multiple transducers to avoid the "motor shadow"? If so, can I use both transducers at the same to get full scan of the left and right side, or do I have to look at one side/transducer at a time?
Guess I need to buy another $250 transducer????
Offline Del
  • Unit(s): 1197 SI
« Reply #4 on: July 07, 2011, 11:13:57 AM »
Your guess is probably not that bad. If your installation is really similar it's probably the best way to install a 2nd transducer. Bother transducers can be connected with an Y-Cable so you will have left reading of the left transducer and right readings from the right transducer - so you'll have both SI returns at the same time.
Before you go on and buy another transducer and install it, i would still consider posting some photos of the original installation on your boat (from the back like the one you've posted and from the side, so we can see if the signal will be blocked - from the left side if the transducer is located on the right, too please) and probably an screenshot of the shadow you're seeing on the unit. I'm still very curious about this need "to tilt the head down to get the sonar to read depth". But if you think you're right, then the 2nd transducer and the Y-cable will be your best solution.
Greetings,
Del
Offline jhcreid
  • Unit(s): 997c
« Reply #5 on: July 07, 2011, 11:46:48 AM »
Will get the pics tomm.. thanks..
Next: I need to install updates; I registered the unit yesterday and the Humminbird website says I needed four updates. What I've done so far is downloaded the updates onto a SD card. Can I simply reset defaults on the unit and plug in the SD to update all in one shot, or do I need to down load to SD, then to unit one at a time? Hope this makes sense.
The unit also came w/the Navionics Premium card that I've tried to update via their website. I downloaded the "Chart Installer" program on my computer. When I place my unlocked Navionics chip into my computer, the computer recognizes it because it tries to open to view contents.
Problem: When I run the Chart Installer program and try to "Get freshest data", the program gets hung up on the "locating your chip" step, like it can’t find the SD card that I know my computer recognized.  Any ideas?
Thanks a bunch!
« Reply #6 on: July 12, 2011, 10:49:33 AM »
Look at the files listed in your Humminbird account again.  Only one of those files is for updating your 997c Si unit.  One is for the HumminbirdPC program and two are converters for a sonar recording viewer program.
When you say that you “had to tilt the head down to get the sonar to read depth”, do you mean that you had to tilt the back end of the transducer downwards to be able to get a depth reading at fast boat speeds?  If so, than this may be normal for your boat.
Offline jhcreid
  • Unit(s): 997c
« Reply #7 on: July 18, 2011, 09:57:54 AM »
So I gotsome great "right side" screen shots of wrecks that I'll be uploading soon. Still no luck with the "left side scan", I've attached some install pics today, looks like I'll be buying the second transducer for the left side? Any input on how this install looks?ila_renderedila_rendered
Offline jhcreid
  • Unit(s): 997c
« Reply #8 on: July 18, 2011, 10:02:23 AM »
Some more.. ;D
« Reply #9 on: July 18, 2011, 11:44:32 AM »
The left side part of the transducer may be getting bubble interference fromm the speed sensor just left of the ducer.
Wow...that is a lot of water spray.....
« Reply #10 on: July 18, 2011, 12:04:44 PM »
Also blockage by the motor to the left of the transducer.
The second HDSi transducer and the AS-Si-LR-Y will clear the missing left Si sonar up for you.
Offline jhcreid
  • Unit(s): 997c
« Reply #11 on: July 18, 2011, 04:03:19 PM »
 :) yeah, I wanted to mention that the above shot was taken at 30mph, I think it's kinda of funny that I've got two wakes behind my boat now. Yesterday was the first time I was running at 30mph and was unable to get a depth reading at around 35 ft of water.
Offline jhcreid
  • Unit(s): 997c
« Reply #12 on: July 18, 2011, 05:35:30 PM »
So I posted some screen shots on the image gallery under "shipwrecks". Notice they're all right side. Got some nice shots up to about 70' of water. All shots were taken in lake Champlain, fresh water.
Offline Del
  • Unit(s): 1197 SI
« Reply #13 on: July 18, 2011, 05:40:47 PM »
To be honest, the speed sensor is really in the worst location. Even moving your transducer might improve your returns.
Greetings,
Del
Offline jhcreid
  • Unit(s): 997c
« Reply #14 on: July 18, 2011, 09:54:06 PM »
Don't use, nor need that freaking thing anyways, maybe I'll just flip it us as the  gps speedo is just fine. We'll try that and see how it goes.  Thanks.
Offline Roddy
  • Scan,scan and rescan
« Reply #15 on: July 19, 2011, 03:25:08 AM »
Remove the speed pitio tube!  Roddy
Scan,Scan and Rescan Roddy
Last post February 24, 2010, 10:43:16 PM
by nsmith997C
Last post June 16, 2010, 11:41:22 PM
by Sonartech
Last post December 13, 2013, 05:38:31 AM
by peterv6i
Last post November 01, 2015, 04:53:54 PM
by joe20toon
Last post May 09, 2019, 02:12:00 PM
by Delta Bass Fool
Last post August 03, 2019, 11:22:25 PM
by Gimp
Last post December 06, 2021, 06:58:25 PM
