Author Topic: Trouble uploading Routes to 899 CI HD  (Read 8926 times)
Offline jnowell
  • Unit(s): 1198
« on: September 09, 2015, 09:21:24 AM »
I've got a fair bit of experience creating routes in Open Captain (free chartplotter) and then exporting them to an SD card using Humminbird PC. I plug the SD into the unit, power it on and it imports the routes automatically. I di this on 1197C SI's multiple times, but it will not work on my brand new 899CI HD. If I upload a .HWR file could anyone diagnose? Any known issues with this unit?
Thanks in advance.
Jason
Re: Trouble uploading Routes to 899 CI HD
« Reply #1 on: September 09, 2015, 10:18:19 PM »
Try powering on the unit first ... And then insert the SD Card ...
That sequence was changed in a software version some time ago to give users more control of when Nav data was actually uploaded to the unit ...
You should get a green popup when you insert the SD Card that you will need to "Yes" or "No" ...
« Last Edit: September 09, 2015, 10:20:34 PM by rnvinc »
Offline jnowell
  • Unit(s): 1198
« Reply #2 on: September 10, 2015, 06:00:28 PM »
Thanks a bunch Rickie, I will try that tonight. I seriously appreciate the help.
Jason
Offline jnowell
  • Unit(s): 1198
« Reply #3 on: September 11, 2015, 12:29:41 PM »
I can't believe it was that simple, worked like a charm. Thanks again!
« Reply #4 on: September 11, 2015, 02:00:18 PM »
This was actually a very beneficial change in the software ...
With the old software ... NAV data was automatically loaded if you happened to mistakenly had a SD Card inserted with Nav data on power up ...
With the new software ... There's actually a green verification popup you must answer before Nav data can be loaded into the unit ...
Last post October 29, 2010, 02:26:34 AM
by Barmic
Last post April 17, 2012, 07:24:56 PM
Last post April 24, 2012, 09:41:08 AM
by wolfs4evr
Last post April 30, 2013, 09:01:19 AM
by N9Phil
Last post April 25, 2014, 03:40:47 AM
by slabbacks
Last post August 21, 2015, 09:45:31 PM
Last post March 07, 2017, 09:56:05 AM
by TheGooly
Last post June 10, 2021, 06:34:34 PM
by ezfishn
