Author Topic: 981c SI menus disappeared completely  (Read 44060 times)
Offline victorstanescu
  • Unit(s): 981CX SI
  • Software: 4.950
« on: July 23, 2015, 05:08:30 AM »
Hello,
After an upgrade to 4.950 (from the original 3.180-i think- version), all the SI options have disappeared from the unit. I have ordered an AS-PC2 cable now and I am waiting for it to come, in order to try the bootstrap option that I have read here about. Somebody else was suggesting to downgrade the unit to an older version (i have found a few versions here on the site) then upgrade back.
As I have seen a few other people encountered the same issue, I have a question for you: has anybody managed to fix this without sending the unit back to Humminbird? For me this would be a very complicated issue, as I live in Romania and I have to send it to US.
If you managed to get back the SI features, what have you done exactly?
Many thanks in advance,
Victor
  • Unit(s): 981CX SI
  • Software: 4.950
Re: 981c SI menus disappeared completely
« Reply #1 on: July 23, 2015, 05:09:32 AM »
Sorry for double post, but to be precise, the unit is a 981CX SI
« Reply #2 on: July 23, 2015, 10:45:14 AM »
Make sure you are not in demo mode, and that you have the advanced user mode selected on the set-up menu.
« Last Edit: July 23, 2015, 10:46:41 AM by ITGEEK »
« Reply #3 on: July 23, 2015, 10:20:31 PM »
Try "Restore Defaults" under the Setup tab ...
If that doesn't help ...make sure the xducer is connected to the unit ... Then ... :
Go under the "Views" tab and make the "Accessories" view "Visible" ...
Then exit out of the menu system and cycle thru the views until you see the "Accessories" view ...
Does it show "Temperature" as "Connected" ...??
« Last Edit: July 23, 2015, 10:25:24 PM by rnvinc »
  • Unit(s): 981CX SI
  • Software: 4.950
« Reply #4 on: August 01, 2015, 06:54:47 AM »
Sorry for the late reply, just yesterday I had time to go to the boat. I have tried:
a) to restore defaults - nothing changed
b) temperature is connected.
c) tried to upgrade/downgrade using the bootstrap procedure. I have reached the bootstrap menu, choosed 9 (program) and pressed view. The sonar said "Programming.." but it was not appearing in HumminbirdPC (I have waited ~5 minutes). In normal mode, when started, it appears very fast in HumminbirdPC. Not being able to update in bootstrap mode, I have updated it to 4.950 and also tried 3.940 (originally it had 4.750, not 4.950 as I wrongly said initially).
Still, I have no side-view scanning options in the sonar and no idea what else to do/try.
I have made photos with all the screens that I have, maybe you observe some issue somewhere.
P.S. I have connected the sensor to an identical sonar belonging to a friend, and using his head unit the sonar works ok in side view, so it is something related just to software.
« Reply #5 on: August 01, 2015, 11:56:59 PM »
I'm at a loss here Victor ...
Your 981 SI does not have a "Transducer Select" menu under the Sonar tab that some of the other newer SI units have ... Which could disable the SI views if a Dual Beam only xducer was selected ...
And interestingly ... Your Sonar tab is not even showing the "Imaging Frequency" selection menu under the "Beam Select" menu like it should ... The manual for your unit shows it should be right under the "Beam Select" menu choice in the Sonar tab ...
http://www.humminbird.com/WorkArea/DownloadAsset.aspx?id=2866
You mentioned that you tried your xducer on another head unit and got SI views to indicate your xducer is working ...
Have you tried your head unit on that other xducer to see if there's any difference ...??
  • Unit(s): 981CX SI
  • Software: 4.950
« Reply #6 on: August 02, 2015, 06:23:19 AM »
Yes, I have also tried the opposite. Nothing has changed (no SI available). But before the software upgrade, all the options were in the right place and working. So it must be related to the upgrade somehow.
« Reply #7 on: August 02, 2015, 09:22:29 PM »
Can you revert the unit back to the version that came in the unit ... ??
  • Unit(s): 981CX SI
  • Software: 4.950
« Reply #8 on: August 03, 2015, 09:26:29 AM »
No, I don't have it (it was too old, something like 3.8 something if I remember correctly).
« Reply #9 on: August 03, 2015, 09:53:13 PM »
Can you try to revert back to one of the previous versions in the Software downloads section ...??
http://forums.sideimagingsoft.com/index.php?action=downloads;cat=6
« Last Edit: August 03, 2015, 09:55:57 PM by rnvinc »
  • Unit(s): 981CX SI
  • Software: 4.950
« Reply #10 on: August 04, 2015, 07:42:46 AM »
Yes, I have already tried this (as said in the post with lots of screenshots). So 3.940 didn't changed anything useful.
« Reply #11 on: August 04, 2015, 11:00:25 PM »
I don't know Victor ... Maybe try one of the other versions and see if there's any difference ...
Let me see if I can get Deborah to pop in here and help you ...
« Last Edit: August 05, 2015, 11:16:28 AM by rnvinc »
Offline HBirdDeborahCRC
« Reply #12 on: August 05, 2015, 03:48:36 PM »
If you have restored the defaults on the unit, and you have tried another transducer on your unit and the unit performs the same way on two different transducers designed for your 981 unit then likely the problem is in the unit.
The distributor for your area maybe able to assist.
ALLTECHNIK/ALLROUND MARIN - AUTHORIZED DISTRIBUTOR
RHEINBOLDTSTRASSE 11-13
BIEDERMANNSDORF , NEUDORF, AUSTRIA 2362
+43 (0)2236/64676-0
+43 (0)2236/64676-76
OFFICE@ALLROUNDMARIN.COM
However, the 981 unit is no longer able to be serviced at the factory.
Last post August 09, 2010, 07:40:16 PM
Last post January 19, 2012, 08:51:42 PM
by gaf11
Last post September 26, 2013, 05:24:12 PM
by brbassfan
Last post July 08, 2014, 03:55:45 PM
Last post January 26, 2015, 01:02:35 AM
Last post October 31, 2015, 11:48:48 PM
by lake anna george
Last post February 16, 2019, 10:21:53 PM
Last post June 27, 2023, 05:31:13 AM
by Papa D
