Author Topic: New Software Released 4.950 for 981c SI  (Read 20426 times)
« on: July 23, 2010, 10:57:50 AM »
Humminbird Released a new software update for the 981c that fixes the Shallow Water Depth issue.  Several other non-SI units recieved updates as well, including the following models:
717
727
737
747c
757c
767
787c2
The download for the 981c can be found here on the forum in the Downloads Section or by logging into your account at Humminbird.com.
Thanks,
Offline sarmax
  • Unit(s): 981c
Re: New Software Released 4.950 for 981c SI
« Reply #1 on: August 08, 2010, 11:14:52 AM »
Loaded to my 981c, works fine except SI views and menus are missing!
SW version was 3.17.
Any help appreciated,
Marko
« Reply #2 on: August 09, 2010, 12:25:20 PM »
Did you reset the menus back to the factory setting both before and after updating the software in the unit?  If not, try resting them now by using the Restore Defaults menu.  If so, try loading an older software version in the unit than download a fresh copy of the 4.950 software and try it again.
Offline sarmax
  • Unit(s): 981c
« Reply #3 on: August 09, 2010, 05:54:01 PM »
Yes, I did reset menus and I also loaded older sw versions but SI menus and views do not show up any more.
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #4 on: August 09, 2010, 07:40:16 PM »
Hi Marko,
the same symptoms showed when I screwed up my first update on my 981.
But there might be a way to restore your unit without sending it back to the factory or dealer. I wrote a "how to" here:
http://forums.sideimagingsoft.com/index.php?topic=661.0
I hope this helps. Keep us posted on the outcome.
Regards from the South
Harry
YES,......
WE SCAN!
Last post October 12, 2009, 07:26:24 PM
Last post June 09, 2010, 08:29:45 PM
Last post June 11, 2010, 08:49:25 PM
by jejb
Last post August 08, 2012, 11:09:00 AM
by Roddy
Last post April 18, 2013, 10:46:47 PM
by Jay415
Last post May 29, 2014, 08:50:37 AM
Last post August 15, 2014, 04:21:38 PM
by Beaulieu80
Last post November 03, 2014, 12:33:07 PM
by Jdeee
