Author Topic: GPS Disappeared!!  (Read 17430 times)
Offline Papa D
  • Unit(s): 898c SI and a 788 ci HD
GPS Disappeared!!
« on: June 26, 2023, 05:14:02 AM »
I just purchased a used boat that came with a Humminbird 898c si Sonar/GPS combo at the console. However, when I power up the unit and go to the “Menu” nothing comes up at all about the GPS. I’ve tried going through the Menu, Views and resetting to the factory defaults but nothing at all about the GPS. I understand it is an older obsolete unit, (And so am I!) but it’s weird that nothing cumes up at all on the menu. Do you have any suggestions?? It also came with a Humminbird 788 ci HD on the bow which appears to be working fine.
Re: GPS Disappeared!!
« Reply #1 on: June 26, 2023, 09:24:13 PM »
xx8 and older units require an external GPS puck antenna  ...
Is there one on the boat somewhere  ... and which unit is the GPS puck connected to  ... ??
« Last Edit: June 26, 2023, 09:26:38 PM by rnvinc »
Offline Papa D
« Reply #2 on: June 27, 2023, 05:31:13 AM »
Thank you so much for the reply, Yes there is an external antennae, however it turns out that it was networked with the 788ci on the bow and one of the outlets in the "Link" box had gone bad. Once I switched the plugs around it all worked. Thanks again!!
« Last Edit: June 27, 2023, 05:33:12 AM by Papa D »
Last post September 26, 2013, 05:24:12 PM
by brbassfan
Last post August 05, 2015, 03:48:36 PM
by HBirdDeborahCRC
