Author Topic: Error message whenever trying to update sd card  (Read 11546 times)
Offline muskydope
  • Unit(s): 798,597,981
« on: July 09, 2015, 06:48:44 PM »
Hi Guys, I'm new to the site and am having problems...looking for some help. I have a number of recordings on a regular sd card. I've uploaded to AutoChart pro, I've converted the files and see the map ready to load on my Humminbird sd card, but I always seem to get an error that the file is too large for the map. I've tried files that were under 100kb and some that were 50mb, but to no avail. I've changed my range from 500 meters out 7000 meters, same problem. I can see the finished looking map on pc just fine, just can't seem to upload it on my Autochart card. What am I doing wrong? Any help would be appreciated.
Thanks, Jim
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
Re: Error message whenever trying to update sd card
« Reply #1 on: August 26, 2015, 10:30:44 AM »
How many track points do you have?
at what step do you get that error from? when you click on create map or on the LakeMaster update button?
are you updating the custom lake directtly to your SD card or to local PC hard drive?
Offline muskydope
« Reply #2 on: September 06, 2015, 02:15:43 PM »
I'm not sure how many track points I have but I run into issues when I try to update the SD card. I can create the map ok on my pc, just can't seem to update the SD card.
Offline Beaulieu80
  • Software: 7.68
« Reply #3 on: September 11, 2015, 12:57:37 PM »
SC card be write protected with the white pin on the side like older disk. check that it may be in READ only mode
Last post September 28, 2010, 12:47:04 PM
Last post April 10, 2013, 05:00:02 PM
by easysailor
Last post November 04, 2014, 12:53:10 PM
by DM
Last post August 05, 2016, 05:23:10 PM
by Scampbell
Last post January 27, 2017, 09:08:38 AM
by Minke
Last post November 10, 2018, 04:09:17 AM
by D S
Last post November 14, 2020, 07:49:46 PM
