Author Topic: Waypoint error message on my Hummingbird 798ci hd  (Read 8519 times)
Offline Gerhard 2020
  • Unit(s): 998c HD SI
« on: November 08, 2020, 09:51:51 PM »
Hi guys
I am getting this message on my Hummingbird 798ci hd, this happens when I select the go to function, ( No more waypoints can be saved. Out of waypoint memory ).
I only have 30 waypoints saved, I have deleted all my routes and tracks, I also deleted some waypoints, I have tried a factory default reset. I have backed up all my waypoints but it did not remove them. Does anyone have any ideas about this.
Regards
          Gerhard
« Last Edit: November 08, 2020, 11:56:02 PM by Gerhard 2020 »
Re: Waypoint error message on my Hummingbird 798ci hd
« Reply #1 on: November 09, 2020, 09:53:49 PM »
Check under the Accessories tab and make sure “Screenshots” is turned off  ...
Then test saving a waypoint and report back here  ...
« Reply #2 on: November 10, 2020, 12:02:50 AM »
Will try tonight thanks
« Reply #3 on: November 10, 2020, 11:36:15 PM »
checked the Screenshots setting, it was turned off. Still getting the same message, checked both my sim card and navionics card both are nearly empty.
No what ????,
« Reply #4 on: November 11, 2020, 08:58:49 PM »
*Export the entire waypoint library to an SD Card  ...
*Go under the Setup tab and down to Format Nav Directories  ... this will clean the waypoint library  ...
*Also Restore Defaults while under the Setup tab  ...
*Then test saving a waypoint  ...
If the issue is resolved - there is a corrupt waypoint in your list causing gremlins and must be investigated in the Humminbird PC software (available for free from the Humminbird website)  ...
Please report back with your findings  ...
« Last Edit: November 12, 2020, 08:50:32 PM by rnvinc »
« Reply #5 on: November 11, 2020, 11:46:10 PM »
Thanks Rickie
will try this tonight, and will let you know
thanks
       gerhard
« Reply #6 on: November 13, 2020, 08:25:23 PM »
Thanks Rickie
Did what you suggested and it fixed it  that was until after I figured out that I needed to turn on advanced  functionality  in the set up. Lol
Thanks all
« Reply #7 on: November 14, 2020, 07:49:46 PM »
Thanks Rickie
Thanks all
There is most likely a corrupt waypoint in your list  ...
Download the free Humminbird PC software from the Humminbird website and load your waypoint data into the program  ...
Look for waypoints with weird dates ... weird latitude or longitude numbers  ... or special characters in the waypoint name  ...
Last post September 28, 2010, 12:47:04 PM
Last post March 28, 2012, 11:04:13 AM
Last post April 10, 2013, 05:00:02 PM
by easysailor
Last post November 04, 2014, 12:53:10 PM
by DM
Last post September 11, 2015, 12:57:37 PM
by Beaulieu80
Last post August 05, 2016, 05:23:10 PM
by Scampbell
Last post January 27, 2017, 09:08:38 AM
by Minke
