Author Topic: Error message upon startup..  (Read 18051 times)
Offline Minke
  • Minke
  • Unit(s): Humminbird 898c SI
« on: January 26, 2017, 02:04:54 AM »
Hi guys!
I´m having a little trouble with my 898c SI..
Upon startup I get the message that there is not enough memory too load all nav data..
I tried too google it but that didn’t help me.. I have checked all my waypoints to see if the names were too long or the time was incorrect but all of them seems fine.
What do I do to fix this problem?
Re: Error message upon startup..
« Reply #1 on: January 26, 2017, 10:43:03 AM »
Remove any SD Cards including mapping cards and test ...
Please report back ...
Offline Minke
  • Minke
« Reply #2 on: January 26, 2017, 10:47:35 AM »
Test...? I`m not sure I know what you mean..?
« Reply #3 on: January 26, 2017, 10:27:19 PM »
Remove any SD Cards and power on the unit to see if that error popup goes away ...
(I'm thinking you may have a corrupt SD Card or corrupt mapping card causing the error popup) ...
Offline Minke
  • Minke
« Reply #4 on: January 27, 2017, 01:40:30 AM »
If thats the case... How do I fix the card? I cant just copy the files to another card..
« Reply #5 on: January 27, 2017, 08:54:21 AM »
That would depend on regular SD Card vs mapping card ...
A regular SD Card might have an issue with the Matrix folder and/or contents ... in which case a different SD Card would be needed ...
A mapping card could be corrupt by accidently exporting Nav data to the mapping card ... in which case you would have to call the mapping card company for advice in how to possibly clean the corruption ...
The 1st issue at hand is to determine if the error popup is caused by a corrupt SD Card, a corrupt Waypoint in the unit memory, or some other gremlin we need to track down ...
« Last Edit: January 27, 2017, 08:55:58 AM by rnvinc »
Offline Minke
  • Minke
« Reply #6 on: January 27, 2017, 09:08:38 AM »
Ok, I will try to test it 👍
Last post September 28, 2010, 12:47:04 PM
Last post November 09, 2010, 03:09:59 PM
Last post April 10, 2013, 05:00:02 PM
by easysailor
Last post November 04, 2014, 12:53:10 PM
by DM
Last post September 11, 2015, 12:57:37 PM
by Beaulieu80
Last post August 05, 2016, 05:23:10 PM
by Scampbell
Last post November 14, 2020, 07:49:46 PM
