Author Topic: humminbird depth finder  (Read 8339 times)
Offline larry crouch
  • Unit(s): 898c&586hd
  • Accessories: lakemaster and navionic
« on: July 04, 2015, 07:01:42 PM »
  How do you get the COG  and other numbers off your read outs? Thanks. Larry
Re: humminbird depth finder
« Reply #1 on: July 04, 2015, 08:50:29 PM »
COG is hard coded in the Readout box when any Chart view is on the display ...
HB thinks you should know where you're going if you're looking at a map ...
Here are your options for customizable Readouts in the 800/900 series units ...
800/900 Readouts
NAVIGATION:
1-Customize
2-Fixed: Heading
3-Fixed: Bearing
4-Fixed: Split: Cross Track Error(XTE) and Distance To Go (DTG)
5-Fixed: Split: Time To Go (TTG) and Speed
CHART:
1-Customize
2-Fixed: Heading
3-Fixed: Customize
4-Customize
5-Fixed: Speed
BIRDS EYE VIEW:
1-4 Fixed with Depth, Heading, Position, Speed
5-customize
SONAR VIEWS:
1-5 Customize
« Last Edit: July 04, 2015, 08:52:37 PM by rnvinc »
« Reply #2 on: July 04, 2015, 08:54:13 PM »
I have read there is a little more choice control in the newest software version ...
Are you on the newest version of software that would be located in your HB account ... ??
Rickie:
« Reply #3 on: July 04, 2015, 10:22:14 PM »
Thanks for the information on the COG. The answer to you question about the newest version is I don't believe so because I'm on 6;40 something. But thanks for your help and I will go to bass pro to get my update this week. I'll then check out what I might be able to do. Thanks again. Larry.
Last post April 15, 2009, 10:07:56 PM
Last post September 14, 2010, 01:33:11 PM
Last post April 06, 2011, 10:49:34 PM
by bassfshn
Last post July 11, 2012, 12:10:32 AM
by LocDown
Last post July 16, 2012, 04:19:22 PM
by catfish21
Last post May 14, 2013, 09:34:49 PM
by easysailor
Last post April 27, 2014, 08:10:49 PM
by Gaylan
Last post February 17, 2017, 10:25:06 PM
by larry crouch
