Author Topic: depth finder odd display  (Read 7536 times)
Offline easysailor
  • Unit(s): 1197c SI nvb, 998 SI,597 ci HD, 999SI
  • Software: 7.67
  • Accessories: TS down riggers, intellitroll
« on: May 14, 2013, 04:12:03 PM »
noticed odd pixel display and DI and side display.  Dirty xducer? now using 6.6
Re: depth finder odd display
« Reply #1 on: May 14, 2013, 05:53:13 PM »
easysailor,
Do you happen to have a screen snapshot of what the Si sonar looked like at this same time?  I don’t think that a dirty transducer would cause this.
Offline short grub
  • Unit(s): 1198 SI combo, 1159 DI combo
  • Software: latest
  • Accessories: terrova 80lb w/I*lLink 360transmt
« Reply #2 on: May 14, 2013, 08:35:16 PM »
Hey easy I'm getting a lot worse pic's these were all with the 6.61 I first thought it was RF noise but after working to correct it I find it still happens even when drifting it seems to go away if I change the sensitivity but will reappear if the depth changes or the locators hick ups I have also got what I will call power spikes unit just flickers and its gone or it comes back
I have tested this when drifting and when the big motor is running and it still happens under each circumstance
 I think this is a software issue that HB is having as it didn't happen with 6.4 software
a few picks
« Last Edit: May 14, 2013, 08:36:28 PM by short grub »
Offline easysailor
  • Software: 7.67
« Reply #3 on: May 14, 2013, 09:34:49 PM »
I resolved the problem by going back to the version 6.31. It happen when I upgraded to 6.6. I thought maybe something happened to my equipment or connections. But that wasn't the case. Version 6.6 seems to have real problems. Display is back to normal.
« Last Edit: May 14, 2013, 09:39:57 PM by easysailor »
Last post October 27, 2009, 02:45:33 PM
Last post April 06, 2011, 10:49:34 PM
by bassfshn
Last post July 05, 2011, 03:43:22 PM
by Chad711
Last post July 11, 2012, 12:10:32 AM
by LocDown
Last post September 04, 2012, 12:46:05 PM
Last post April 27, 2014, 08:10:49 PM
by Gaylan
Last post July 04, 2015, 10:22:14 PM
by larry crouch
Last post February 17, 2017, 10:25:06 PM
by larry crouch
