Author Topic: Humminbird GPS System In-Depth...  (Read 9977 times)
Offline DougV
    • Doug Vahrenberg Professional Angler
  • Unit(s): 1197c, 898c
« on: September 09, 2010, 07:46:53 PM »
Global Positioning Systems are not all created equal and in today's modern world. GPS was founded to help Armed Services locate position and use for protection and guidance. Well today GPS is being used more and more by a wide variety of industries. Look at farming GPS Position can guide or steer machinery with Centimeter accuracy but these systems can cost approximately $50,000 and require Base Station Correction signal or Annual Subscription Fees to get this level of Accuracy.
Humminbird with the GR-50 Receiver we will see offers outstanding accuracy for standard Equipment Receiver on all Internal and External Receiver in the 700, 800, 900 and 1100 Series Units. A 50 Channel Receiver can maintain a lock on 50 different satellites at a single time which allows for faster acquisition of location and maintaining the lock on the satellites as they begin to leave the horizon and pick up new satellites as they start rising in the horizon. The more satellites the higher the accuracy level to calculate your exact location time after time, year after year. The GR-50 when hooked direct into the unit will provide 4 Times per Second Refresh Rate of your location which allows for faster direction changes and tracking your exact location.
Here is a Screen Capture of the GR-50 the other day tracking 17 Satellites at one time:
Here is the Current Satellites Planned and Orbiting From the 3 Northern Hemisphere Constellations.
US Constellation: 32 Satellites with 28 Useable
GLONASS (USSR): 24 Satellites Planned with 20 Useable
Galileo (European Union): 30 Satellites Planned and 2 Useable
This data was the most recent I have been supplied, may be more satellites available.
On the GPS Diagnostics Screen one thing I like to look is HDOP Calculation. This is the Horizontal Dilution of Precision which is the measurement of the contribution of satellite geometry to the uncertainty in a position fix. The lower the number the better. Here's a refence chart to valves and relevance of the GPS Data:
   1: Ideal - This is the highest possible confidence level to be used for applications demanding the highest possible precision at all times.
1-2: Excellent - At this confidence level, positional measurements are considered accurate enough to meet all but the most sensitive applications.
2-5: Good - Represents a level that marks the minimum appropriate for making business decisions. Positional measurements could be used to make reliable in-route navigation suggestions to the user.
5-10: Moderate - Positional measurements could be used for calculations, but the fix quality could still be improved. A more open view of the sky is recommended.
10-20: Fair - Represents a low confidence level. Positional measurements should be discarded or used only to indicate a very rough estimate of the current location.
  >20: Poor - At this level, measurements are inaccurate by as much as 300 meters with a 6 meter accurate device (50 DOP × 6 meters) and should be discarded.
How to Find the Accuracy of your Humminbird
The GPS Diagnostic View can tell you alot about the performance of your GPS Receiver and the Reception you are receiving. To get to the GPS Diagnostic View you can access it through the Start-up Menu or the easiest way is to go into the Master Menu (Hit Menu Twice) then scroll with 4 Way cursor over to View Tab. Hit Up Arrow on the cursor and towards the bottom you will see the GPS Diagnostic View and status will be Hidden. Turn it on to Visible. (See Pic Below)
Now page through the VIEWS to get to the GPS Diagnostic VIEW. Hitting VIEW will page forward. EXIT will page backwards through the VIEWS. It will look like the Image Below.
So what does all this mean and how do I use it? We will go through each letter and explain what it is and what it does.
A: The "Bullseye" tracks the satellites and tells you signal strength of each one. Depending on the Channel of GPS Receiver you have you may see more or less. GR-4 tracks up to 4 Satellites, GR-16 up to 16 Satellites and the new Standard Equipment on many models the GR-50 can track up to 50 Satellites. The Bar Graph next to each number tells you signal strength. THe darker the number the stronger the reception. This correlates to the distance the satellite is from the center or your location. The more satellites near the center or represented in black the better the postion or accuracy to mark your location.
B: Is the type of fix you are getting. No Fix, 2D Fix, 3D Fix or Enhanced. Enhanced is the highest level. Enhance uses correction data from WAAS, EGNOS or MSAS to help increase position accuracy. A 3D or Enhanced Fix is need for Navigation.
C: HDOP or Horizontal Dilution of Precision. Is a value for the current position of the satellites used to calculate accuracy. The lower the number the better the accuracy. Humminbird usually shots for 0.6 to 3 for best accuracy levels. Here is some good reading on Wilkipedia: http://en.wikipedia.org/wiki/D...PS%29
D: Estimated Position Error is the estimated distance the current position is off from being exact. Humminbirds average is less than 2.5 Meters or 8.2 Feet.
E: Altitude is the calculated height of the GPS Receiver above sea level.
F: Speed: Is the GPS Calculated speed
G: Course: Is the direction the boat is heading. 0/360 Degrees is straight North, 90 Degrees is East, 180 is South and 270 is west.
H: Left Card Reader Slot. In this example I have a HyCapcity SD Card with 3.63 GB of 3.8 GB left for storage.
I: Right Card Reader Slot: In this example I have a Navionics Premium East Card installed and the unit recognizes it.
J: Current GPS Position
K: Time and Date from the GPS Receiver
L: Type of GPS Receiver the Unit is Using
M: Selected Readouts. These are the user defined readouts that are displayed in all VIEWS. I have Depth, Position, Speed. Course and Volts selected.
FYI: GPS Satellites transmit the time and date and the receiver uses the time and date information to calculate the distance from the satellite. This is how GPS position can be determined by receiving multiple Time and Date Transmissions and calculating the position on earth compared to satellite location and time and date.
Hope this helps you understand the relationship and performance differences between the different GPS Systems available for recreational use Plus how to know the accuracy of saving waypoints and returning precisely back to them.
Offline DougV
Re: Humminbird GPS System In-Depth...
« Reply #1 on: September 13, 2010, 12:22:18 PM »
I've had several ask about the GR-16 Receiver and if you hook it direct or to the AS-YC Cable (Not Thru InterLink) it will too get the 4 Times Per Second Refresh Rate.
« Reply #2 on: September 14, 2010, 01:33:11 PM »
Just make sure they are running the 4.700 or newer software.
Last post April 15, 2010, 01:11:25 PM
by Dam Yankee
Last post September 06, 2013, 09:51:47 AM
Last post April 03, 2014, 11:12:28 AM
Last post October 31, 2014, 08:34:32 PM
Last post January 04, 2015, 06:03:08 PM
Last post March 04, 2015, 05:35:32 AM
by Sasch
Last post July 04, 2015, 10:22:14 PM
by larry crouch
Last post October 17, 2017, 08:00:10 PM
by ckd022
