Author Topic: 1.6 Feet?  (Read 9605 times)
Offline jazz4627
  • Unit(s): 797
  • Accessories: Interlink
1.6 Feet?
« on: June 07, 2015, 03:47:04 PM »
So I recently bought a bigger boat and it came with the 2 797's. The in dash one will work for a short bit then just start displaying the depth as 1.6 feet and at that point nothing else seems to be working right. I am guessing I need a new transducer but I will be dammed if I can find anywhere on the web what the exact one I need is. Any help would be appreciated.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
Re: 1.6 Feet?
« Reply #1 on: June 07, 2015, 04:10:10 PM »
Here's a link to the unit specs. Scroll down.  Looks like it's the..... Transducer Standard:XNT 9 SI 180 T
        http://www.humminbird.com/Products/797c2-SI-Combo/
       Mike
Offline mako9man2
  • Unit(s): 999ci HD SI
Re: 1.6 Feet?
« Reply #2 on: June 07, 2015, 07:04:26 PM »
This may have nothing to do with your problem but on a recent outing my 999 suddenly began reading 1.6 ft depth when I got on plane.  It seemed fine at trolling speeds. I have two transducers, the HDSI transducer for DI/SI and a second for 2D sonar and temp.  The 2D provides the depth reading and the transducer is transom mounted.  I had apparently hit some floating debris and it popped it out of the bracket.  I discovered the problem when I got home, . snapped it back in place and it has been fine ever since
Offline jazz4627
  • Unit(s): 797
Re: 1.6 Feet?
« Reply #3 on: June 07, 2015, 08:39:33 PM »
TY all. I did look at transducer and it seems to be sitting correctly.
Re: 1.6 Feet?
« Reply #4 on: June 08, 2015, 12:22:58 AM »
Is there a "shoot thru" xducer in this setup with the AS SIDB Y cable ...??
Offline jazz4627
  • Unit(s): 797
Re: 1.6 Feet?
« Reply #5 on: June 08, 2015, 11:12:05 AM »
I believe there is a shoot thru also. Need to confirm I guess
Re: 1.6 Feet?
« Reply #6 on: June 11, 2015, 12:09:58 AM »
If there is a shoot thru and a connected AS SIDB Y cable ...
Disconnect the AS SIDB Y cable and plug the SI xducer directly into the head unit ...
If the depth issue issue goes away ... There could be problems with the AS SIDB Y cable, the shoot thru xducer, or the shoot thru installation has been compromised ...
« Last Edit: June 11, 2015, 12:11:07 AM by rnvinc »
Last post April 30, 2010, 04:36:07 PM
by nmanley
Last post July 11, 2011, 04:32:12 PM
by calli1
Last post January 21, 2012, 09:36:17 PM
by T.G
Last post December 28, 2013, 04:32:14 PM
Last post May 19, 2014, 02:49:10 PM
Last post August 12, 2014, 12:42:12 PM
Last post July 04, 2016, 08:02:17 AM
by Beaulieu80
Last post April 06, 2018, 12:49:43 PM
by D Johnson
