Author Topic: SI settings for 30 feet  (Read 10989 times)
Offline Foster78
  • Unit(s): 987 SI
« on: May 23, 2011, 05:11:37 PM »
What do I need to set my freq and sensitivity for no more than 30 feet deep in fresh water? I'm looking to get the clearest picture.
Re: SI settings for 30 feet
« Reply #1 on: May 24, 2011, 02:53:52 PM »
Basically the same as for any Si unit: set the Chart Speed to match your boat speed.  Si Range should be 2x to 3x the water depth.  I would use the 262kHz Si sonar frequency so that it will cover a larger area.  Once you find something interesting you can change to the 455kHz setting, lower the Si Range and make another pass closer to the object.  Set the Si Sensitivity just high enough so that the white sonar returns are not so bright that they overpower weaker sonar returns.
Be sure and update the software in your 987c Si unit of you are not running version 4.770 in it now.
Offline Man Down
  • Unit(s): 987csi
  • Software: 3.17
  • Accessories: GPS, additional in hulll transducer
987c si
« Reply #2 on: July 11, 2011, 07:31:12 AM »
were do you get the software update?
Offline calli1
  • Unit(s): 1198 S I & 787c2i
« Reply #3 on: July 11, 2011, 04:32:12 PM »
You need to register your product with Humminbird.  You can also retrieve some of the downloads on this website.  Good Luck......
Last post April 30, 2010, 04:36:07 PM
by nmanley
Last post January 21, 2012, 09:36:17 PM
by T.G
Last post July 22, 2013, 01:55:23 PM
Last post December 28, 2013, 04:32:14 PM
Last post May 19, 2014, 02:49:10 PM
Last post March 10, 2015, 07:55:16 PM
by Idaho
Last post May 06, 2015, 01:21:16 PM
by KJ
Last post July 04, 2016, 08:02:17 AM
by Beaulieu80
