Author Topic: Xducer depth reaing limit - cannot under 3 feet  (Read 10133 times)
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« on: June 27, 2016, 03:23:55 PM »
Is there a limit to how the unit can read without error?
my boat at the dock have 2 feet of water under the Xducer.
Why it display 16 feet?
why when travelling 25Mhp on 2 feet of water i keep having 800 feet of water?  What makes my unit going crazy at low, strationnary or high speed of not reading under 3 feet of water?
I hav latest softare for my 798 cix hd si
Offline Spd 135
  • Unit(s): 898c si 997c SI Helix 12
  • Software: All Current
  • Accessories: 360
Re: Xducer depth reaing limit - cannot under 3 feet
« Reply #1 on: June 27, 2016, 06:02:25 PM »
It sounds like the transducer is tilted or out of level.
Offline Beaulieu80
  • Software: 7.68
« Reply #2 on: June 27, 2016, 09:53:48 PM »
tilted?
when i am at the dock standing it shows 18 feet when i normally hvae 3..  ducer is not well oriented?
Offline Spd 135
  • Accessories: 360
« Reply #3 on: June 28, 2016, 11:12:19 AM »
That would be the first thing I would check.  If the transducer is not level and the bottom gets deeper away from the boat, you can get an errant signal returned which will be more deep.  Straight down the transducer should give an accurate depth.  If that does not fix the issue, I don't know what else will.
Offline Beaulieu80
  • Software: 7.68
« Reply #4 on: July 04, 2016, 08:02:17 AM »
I try this weekend to change my setup, the level, degree and still showing 16 feet insted of one foot since the water level change since last week.
I have the compact SI Xducer of my 798SI unit
we cann see my installation from the Gallery section under my Username Beaulieu80,  image name DSC03742
Last post February 02, 2010, 12:59:37 PM
by FuzzyGrub
Last post April 30, 2010, 04:36:07 PM
by nmanley
Last post March 05, 2011, 12:34:17 PM
by Roddy
Last post May 01, 2011, 03:36:42 PM
by Roddy
Last post January 17, 2012, 06:43:41 PM
by Singleshot
Last post December 30, 2012, 10:00:30 AM
Last post May 19, 2014, 02:58:15 PM
Last post August 12, 2014, 12:42:12 PM
