Author Topic: New Onix 10 won't network with 1199  (Read 10927 times)
Offline kdietz
  • Unit(s): Onix 10, 1199 HD SI
  • Software: Onix v 2.3, 1199 v 7
  • Accessories: Heading Sensor Antenna
« on: May 25, 2015, 12:40:50 PM »
I've got the latest software downloaded on both units but I can't get the network to work.
Also, I'm using the same ethernet cable that I used when I had the 1199 networked to a 998...correct or is there a special cable for the Onix?
Suggestions?
« Last Edit: May 25, 2015, 12:48:08 PM by kdietz »
Re: New Onix 10 won't network with 1199
« Reply #1 on: May 25, 2015, 02:32:44 PM »
I don't think the units will show up on each others network listing, but should share waypoints.......Maybe someone who has done it will check in an help you out.
Offline kdietz
« Reply #2 on: May 25, 2015, 03:36:18 PM »
I thought the new upgrade would allow them to share maps, settings, etc?
« Reply #3 on: May 25, 2015, 07:38:07 PM »
The 98 series will only share waypoints ..... I think the 99 series will share I-pilot spot locks and tracks also........ but I couldn't find the link that details the difference between the 98 and 99 series.......... but only Onix to Onix will share maps......Onix must be at the new 2.31 for
Offline kdietz
« Reply #4 on: May 26, 2015, 08:18:44 AM »
Bob, thank you for your help! I was miss informed about the extent of the 2.30 upgrade! I see now that I'll only be able to share waypoints and iPilot info!
The waypoints were the most important thing that I wanted!
« Last Edit: May 26, 2015, 06:46:27 PM by kdietz »
« Reply #5 on: May 26, 2015, 03:42:16 PM »
The waypoint sharing was the primary thing that we asked for ..... They jumped thru a lot of hoops to get that working for us.....
Let us know how the Onix / core combinations works out for you...
Last post July 01, 2014, 02:12:18 AM
by Nitro78
Last post May 09, 2014, 05:15:52 PM
Last post April 22, 2015, 10:04:41 AM
by javac
Last post May 13, 2015, 06:43:04 PM
by wconn1979
Last post June 14, 2015, 11:02:19 AM
by kdietz
Last post May 31, 2016, 11:27:43 AM
by Fishin Impossibile
Last post April 02, 2017, 10:25:20 PM
Last post April 23, 2019, 08:32:59 PM
by larryk
