Author Topic: 1198 & 1199 Network  (Read 8656 times)
Offline Fishmeister
  • Unit(s): 1198 & 1199
1198 & 1199 Network
« on: April 02, 2017, 03:35:52 PM »
Can someone tell what I need to network a 1198 & 1199 together.
The 1198 is on the console and the 1199 is on the bow.
Re: 1198 & 1199 Network
« Reply #1 on: April 02, 2017, 04:15:41 PM »
You will need an Ethernet adapter cable for the 1199 and and Ethernet cable long enough.
http://www.humminbird.com/Products/AS-EC-QDE/
The Ethernet cable is AS EC XXE  ....Where the XX is the length.  http://www.humminbird.com/Freshwater/Product-Category/Accessories/Cables/?facets=7319%2C
Offline Fishmeister
« Reply #2 on: April 02, 2017, 05:48:09 PM »
Thanks.  Do you know of some place on the web that tells me how and what to do?
« Reply #3 on: April 02, 2017, 06:33:08 PM »
It's pretty straight forward to connect the units ..... beyond that, it depends on what you want to do with the network.  Waypoints will pretty much share between units automatically ..... You can do transducer sharing also, and that setup  will show up in the network setup menu once the units are connected.
If you do a Google search for Humminbird Ethernet Manual you will find a PDF manual.  There may be some old versions floating around out there, so get the newest one you can find.
« Reply #4 on: April 02, 2017, 10:25:20 PM »
Last post December 30, 2013, 08:47:55 PM
by Rotus623
Last post January 07, 2014, 12:11:19 PM
Last post July 01, 2014, 02:12:18 AM
by Nitro78
Last post August 18, 2014, 01:19:01 PM
Last post September 03, 2014, 12:03:57 AM
by mike82
Last post May 26, 2015, 03:42:16 PM
Last post May 31, 2016, 11:27:43 AM
by Fishin Impossibile
Last post January 04, 2021, 09:50:10 PM
