Author Topic: Network Onix and Solix  (Read 8286 times)
Offline larryk
  • Unit(s): Onix10 si
  • Accessories: ipilot and 360 imaging
« on: April 22, 2019, 10:24:46 PM »
I know this subject has been kicked around already but I'm kinda dense and still don't get it.  I have an Onix 10 and a Solix 10 networked along with a 360, ipilot, ilink using the transducer for the Solix. Solix does not have the latest update because I heard the Onix would not work properly if it was. Everything else has the latest updates. My problem is on my Onix the only thing I can get on the screen is the GPS and the 360... I was expecting 2d, si, and down imaging to work.... Was I just wishing or do I have something screwed up.
Re: Network Onix and Solix
« Reply #1 on: April 22, 2019, 11:04:10 PM »
You are correct the latest SOLIX update eliminates the possibility of sharing anything with ONIX  ...
With as many ethernet items in your Setup I would assume you also have the AS ETH 5XPG ethernet switch  ...
It may be a good idea to disconnect everything from the Network and test with only 1 ethernet cable between the SOLIX and the ONIX to see if they will configure  ...
Offline larryk
« Reply #2 on: April 23, 2019, 03:15:37 PM »
So you say to connect an ethernet cable between the 2 to see if they will configure.... Are they capable of configuring and sharing all available sonar options with the one transducer? Or am I trying to do something that does not work. Scratching my head on this one and not getting any definate answers and I'm sure someone out there has tried this.
« Reply #3 on: April 23, 2019, 08:19:39 PM »
SOLIX and ONIX should share Waypoints, accessories, Sonar, and mapping up until the latest version for SOLIX  ...
Reducing the ethernet network down to 2 head units and 1 cable helps determine if the issue is in either head unit  ...
« Last Edit: April 23, 2019, 08:21:23 PM by rnvinc »
Offline larryk
« Reply #4 on: April 23, 2019, 08:32:59 PM »
Thank you... I'll check it out this weekend.
Last post April 08, 2013, 10:27:53 AM
Last post July 12, 2013, 09:07:35 PM
by tgordon
Last post December 30, 2013, 08:47:55 PM
by Rotus623
by Nitro78
Last post February 15, 2015, 09:55:42 PM
by locoengineer
Last post May 13, 2015, 06:43:04 PM
by wconn1979
Last post May 26, 2015, 03:42:16 PM
Last post April 26, 2018, 08:43:57 AM
by Woollybob
