Author Topic: Keeping the screen clean  (Read 27051 times)
Offline backlashed
  • Unit(s): 898c Combo
  • Software: 6.49
« on: May 04, 2013, 04:29:26 PM »
I can't seem to keep my grubby hands off of the screen, and the rags in my boat are as dirty, or dirtier than my hands, so I came up with this to keep eyeglass cleaning wipes close. I know they're supposed to be waterproof, but I never liked spaying them with cleaner. I've used these wipes for several years now on all my other units I've had, and never had a problem.
I double sticky taped a small ziplock bag to the inside of my unit cover, and keep half a dozen or so wipes in it.
Offline backlashed
  • Software: 6.49
Re: Keeping the screen clean
« Reply #1 on: May 04, 2013, 04:52:04 PM »
I guess I should have researched this better before posting.
Does this recommendation from 2010 still hold true?
Quote
What products can be used to clean my display?
Humminbird recommends using Windex® Vinegar Multi Surface(in the spray bottle).
Do NOT use any wipes products (which can also be available as the brand name Windex Multi-Task).
The lens contains a special coating which improves visibility.  It is recommend to use the above cleaner because we have tested and proved this cleaner.  It does not deteriorate the coatings on the lens.
Offline Fast Eddy
  • Unit(s): 598 ci si
« Reply #2 on: May 04, 2013, 07:23:40 PM »
I could be wrong but.... I think what you are using is fine - and the warning is for household type window cleaning products.  I use plastic eyeglass cleaners all the time on screens - no issues
Offline werethefugowee
  • Unit(s): 997si
  • Software: Downimaging
  • Accessories: speed
« Reply #3 on: May 04, 2013, 07:41:47 PM »
I used a piece of clear flexible plastic like the stuff you Grandma used yo put on the couch cushions. Any fabric store sells it and for about a buck it makes a great scratchproof screen cover. Cut it perfectly to size - and with a few drops of distilled water - put it on. If I'm not mistaken I got that hint right here a couple years ago. Still the same one and it's been on my 997 for at least 2 years.
Offline RuffWood
  • Unit(s): 898c SI, 998c SI, 998c SI, 1199ci HD SI
  • Software: 7.250, 7.510, 7.460
  • Accessories: AS GPS HS, Ethernet, AS ETH 5PS
« Reply #4 on: May 05, 2013, 11:55:10 AM »
The advantage to using the Windex MULTIsurface vinegar in the spray bottle is when you spray the screen you loosen and wash a lot of the grit off the screen. Wipe it dry with a microfiber cloth and you will be surprised how much this improves your view. Though the wipes are damp and better than just usung a dry cloth they do not clean the screen as well and prevents scratches like you do when spraying it down.
« Reply #5 on: May 06, 2013, 03:56:01 PM »
Though i agree with RuffWood about the advantages of a spray versus wipes, I think that warning was specific for the Windex Multi-Purpose (or maybe it was Multi-Surface) wipes which used a different chemical mix versus the spray stuff.  We still only recommend the spray:
http://www.humminbird.com/FAQ.aspx?ContentId=1833
Last post May 30, 2010, 03:04:40 PM
by vmoyers
Last post May 30, 2010, 02:57:38 PM
by vmoyers
Last post April 24, 2012, 08:45:14 AM
Last post May 31, 2012, 04:48:14 PM
Last post December 01, 2013, 08:36:04 PM
by Moose1am
Last post December 16, 2013, 04:24:40 AM
by Rüdiger
Last post January 17, 2016, 09:38:56 AM
by larry crouch
Last post March 05, 2019, 06:20:57 AM
by Fishton
