Author Topic: new 999 si install and left side issues  (Read 7022 times)
Offline Stano
  • Unit(s): 798 ci 999 hd si
  • Software: latest
« on: April 14, 2015, 08:01:00 AM »
Hey thanks for the add i think i may have found my issue but want a second  opinion.  I have what i think are echo lines in the left side si and down imaging i have read on here this to be a jackplate issue? I have attached a few pics of the issue anyvand all help would be greatly appreciate thx in advance
Re: new 999 si install and left side issues
« Reply #1 on: April 14, 2015, 08:14:50 AM »
Welcome to the Humminbird Side imaging Forums Stano.
You do look to have some type of Si sonar reflection as seen in the Di sonar image you posted but without seeing an Si View we will have to take you at your word that it is only in the left Si sonar data.  Although more common, I don’t think that this is a sonar reflection from the jackplate as your transducer looks too low on the transom for that.  Instead I think that it may be the water intake screen causing this.  Is there some way that you can take it off just to test and see if the constant left SI sonar line goes away or not?
Offline Stano
  • Software: latest
« Reply #2 on: April 14, 2015, 08:31:45 AM »
Well i had thought that to.... the lines in the si are on the left side si same double line (forgot to snap a pic)the speed of the boat made no difference and the lines correspond to roughly the same depth.....do you think moving the ducer too the jackplate with a mount would be a better position?  I dont mind losing depth readings on pad
« Reply #3 on: April 14, 2015, 08:59:19 AM »
I was thinking more along the lines of flattening the water intake screen a wee bit and/or adding something as a spacer between the transducer and the hull.  i know that some guys have found lower profile water intake screens.
Last post October 22, 2011, 07:01:20 PM
by jgollihar
Last post April 10, 2012, 08:36:22 PM
by coriobay
Last post March 25, 2013, 11:06:36 PM
by Bassgrabber
Last post March 12, 2013, 10:30:15 PM
by autopilot70
Last post June 06, 2013, 06:05:53 PM
by matt 01
Last post June 27, 2014, 12:53:32 PM
Last post January 26, 2019, 06:08:30 PM
by WiNorthOutdoors
