Author Topic: Interference from gas motor only when in gear  (Read 10829 times)
Offline Slinger
  • Unit(s): 898, 798, 787
« on: April 13, 2015, 03:57:05 PM »
I have a fiberglass multi-species boat with shoot-thru-hull and HD SI transducers connected to an 898C SI with a Y cable.  The main motor is a Yamaha F150 outboard.  This setup worked great for a couple of years, but the factory installed shoot-thru-hull transducer stopped working last fall.  I cut that one off the hull, sanded down to the fiberglass, and installed a new XP 9 20 T in the same place.  Now I'm getting interference from my main gas motor, but only when it's in gear and at RPMs above idle.  If I put the motor in neutral and throttle up, there is no interference.  Also, if the boat is moving in gear at idle speed or just a little faster, there is no interference.
The interference shows up as blue and green pixels from the top of the screen to the bottom, which turn to orange and red as the boat accelerates.  At that point, the sonar loses track of depth.  See the attached image.  The vertical bars of blue/green pixels occurred when I hit the throttle with the motor in gear.
For troubleshooting, I did the following:
- turned off and stowed the trolling motor
- disconnected the other sonar unit and accessories
- removed the Y cable, using only the XP 9 20 T
- removed the transducer cable from the wiring channel in the side of the boat and ran it across the deck and straight into the back of the 898
- removed the temperature probe from the transom and pulled it up to the deck away from any other wires
- swapped a 798 in place of the 898
- reset to factory defaults
- adjusted the noise filter
None of the above made any difference.  Well, the noise filter may have reduced it somewhat, but not enough to be useful.  Any ideas?
Re: Interference from gas motor only when in gear
« Reply #1 on: April 13, 2015, 04:11:52 PM »
Is your prop all dinged up?
Offline Slinger
« Reply #2 on: April 13, 2015, 04:19:56 PM »
No, it's a stainless 3 blade prop, and there's only one tiny ding on the edge of one blade that was there before the original transducer failed.  It's really small (maybe 1/4" long, 1mm deep), and it wasn't a problem with the original transducer.  Other than that, the prop is pristine.
Offline Slinger
« Reply #3 on: April 13, 2015, 04:40:30 PM »
In case it matters, here are couple of images that show the installation of the transducer and the external transom area.  In the photo of the transducers (Humminbird on the right), you can see the transom plug right between them.
« Reply #4 on: April 14, 2015, 08:05:27 AM »
I don’t know than Slinger.  Very rarely a nicked/bent prop will cause this but if it was not doing it with the original transducer it should not be doing it with the new transducer.  Call the Humminbird Customer Service folks.
Offline Slinger
« Reply #5 on: April 14, 2015, 03:19:47 PM »
OK, thanks for taking a look.  I'll post a follow up if I get it figured out.
« Reply #6 on: April 14, 2015, 04:27:59 PM »
Thanks, that may end up helping someone else with the same problem.
Last post March 18, 2011, 06:27:53 AM
by SaminVa.
Last post March 03, 2011, 02:41:25 PM
Last post January 19, 2013, 10:43:18 AM
by walleye10000
Last post June 26, 2012, 03:42:24 PM
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post April 09, 2013, 07:20:16 AM
Last post June 11, 2013, 11:28:36 AM
Last post April 14, 2014, 07:07:56 PM
by tokerwashere
