Author Topic: AutoChart Pro error  (Read 12917 times)
Offline knrm02
  • Unit(s): 997cx SI 1198cx Deepvision DE680DSSP
  • Software: 5840 7640 Deepview4X
AutoChart Pro error
« on: March 21, 2015, 05:20:49 PM »
I have a problem with my Autochart pro i get the error. The new area did not fit inside the current custom map.
It occure on the last stage.
any help is welcome
Offline CamoHunter
Re: AutoChart Pro error
« Reply #1 on: March 23, 2015, 01:31:33 PM »
It is because you have already created a custom map somewhere else.  Did you use the tutorial files and create a custom map there, which is in northern Minnesota?
If you did, or if you created a map somewhere else, when you mapped that area, that defined your custom map area 620miles x 620miles(1,000km x 1,000km).  So, when you tried adding the map area for your lake in your attached screenshots, it gave you an error because that new area is well outside 620 miles from the first map you created in Autochart.
Here's how you can fix it. On your zerolines sd card, rename the AC folder to AC1. Then create a new folder titled AC. Go back into Autochart, and map your area in your screenshots. You should be good as gravy from there!
Or, if you want to get rid of any maps you've already created, you could just delete the AC folder, and create a new one.
Offline knrm02
« Reply #2 on: March 23, 2015, 02:26:05 PM »
Thank you for the help camohunter, i will try it again.
Can i delete the AC folder on the zero lines card,i tried to make a new one on the zero lines card but it was not possible.
Offline CamoHunter
« Reply #3 on: March 23, 2015, 03:41:52 PM »
Tried to make a new what?  AC folder?
If you're not comfortable deleting the AC folder, you can just rename it to AC1.  Then create a new folder titled AC.
If you need anything else, let me know.
Offline knrm02
« Reply #4 on: March 25, 2015, 02:21:20 PM »
CamoHunter i did make a new folder AC and rename the first one AC 1 and the programme works thank you.
I put the zero lines card in my headunit and it shows my first mapping area.
You could see the tracklines in the map,but i think it is in the settings i must look for.
Thank you for the help on the other side of the ocean.
Last post December 17, 2009, 11:37:18 AM
Last post August 31, 2014, 08:03:46 AM
by Trytoofish
Last post November 04, 2014, 12:53:10 PM
by DM
by CamoHunter
Last post April 24, 2015, 02:22:16 PM
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post March 15, 2017, 10:51:17 AM
by mako9man2
Last post September 06, 2018, 01:25:30 PM
by D S
