Author Topic: Autochart Out of memory error  (Read 12877 times)
Offline Trytoofish
  • Software: 2.0, 7.51,
« on: August 26, 2014, 07:39:27 PM »
Have any of you using autochart got an "out of memory" when trying to load SI data? I have a 3 hour recording. 2d loads and maps fine. But when I try to load si data. I get out of memory and Autochart shuts down.
Try Too Fish  Forced To Work
Offline jimham82
  • Jim Hammond
    • LakeImages Training
  • Software: Latest Versions
Re: Autochart Out of memory error
« Reply #1 on: August 31, 2014, 12:10:26 AM »
I would go to settings and check the size of your internal map.   The bigger it is, the less likely you can add SI images.
If that doesn't work, download the HumViewer application from the web.  You can break up your long recording into sub-recordings.   You can then load those.
Offline mmikos
  • Unit(s): 899ci HD
  • Software: 7.2
  • Accessories: autochart pro, ipilot
« Reply #2 on: August 31, 2014, 06:02:54 AM »
you will also get an out of memory message if your SI recording resolution is set to high..middle settings under SI settings is a good compromise
Offline Trytoofish
« Reply #3 on: August 31, 2014, 08:03:46 AM »
THANK YOU! Both! that helped You should be Customer service employees for Humminbird! THEY HAVE BEEN WORKING ON THIS FOR A WEEK AND WERE ALMOST INSISTENT IT WAS A LAPTOP ISSUE.  And no solution yet from them. Its really frustrating when CS dont know whats UP.
I think Humminbird needs to spend less time on kicking products out the door and focus more on training fo CS people and get some of the past issues like sonar code resolved. They seem more focused on the new customer than the current one. IMO.
« Last Edit: August 31, 2014, 08:15:27 AM by Trytoofish »
Last post February 27, 2010, 04:05:06 PM
Last post May 29, 2011, 03:29:04 PM
Last post July 11, 2014, 08:21:41 PM
by JR123
Last post November 04, 2014, 12:53:10 PM
by DM
Last post March 25, 2015, 02:21:20 PM
by knrm02
Last post April 14, 2016, 11:08:48 PM
by CamoHunter
Last post May 05, 2016, 09:00:18 AM
by Beaulieu80
Last post September 06, 2018, 01:25:30 PM
by D S
