Author Topic: Autochart Pro vs Autochart Zero Lines  (Read 29796 times)
Offline nullpointer
  • Unit(s): Helix 7 SI GPS
  • Software: -
  • Accessories: -
« on: March 15, 2017, 03:54:51 AM »
Hello.
I have recently bought my first boat, and a Helix 7 SI GPS unit.
With that unit I am looking at either buying AutoChart Zero Lines or AutoChart Pro.
Since Pro is 2½ times more expensive than Zero Lines (here in Denmark) there needs to be a good reason to choose Pro over Zero Lines.
On HB's website I cant really clearly understand what Zero Lines actually is, is it a chart used in conjunction with AutoChart Pro - to transfer maps from unit to unit. Or is Zero Lines "Some of the basic features of AutoChart Pro".
I know that with the Pro version you can read bottom hardness, 3D models of the water, overlay SI mosaic and you get a computer program and all sorts of things. I do not need that.
All I need is a color coded depth chart of the fjords i fish.
Like so: https://i.ytimg.com/vi/fxG_afpWsrY/hqdefault.jpg
My local dealer dident quite know what Zero Lines could actually do, he talked about the details being less on Zero Lines than on Pro - depth interval was set to 3 feet on Zero Lines instead of 1 feet on the pro version, but that just seems weird.
So, help? Do I need Pro or Zero Lines?
Offline mako9man2
  • Unit(s): 999ci HD SI
Re: Autochart Pro vs Autochart Zero Lines
« Reply #1 on: March 15, 2017, 10:41:07 AM »
There are two AutoChart software packages:  AutoChart and AutoChart Pro.
Each of these packages allows you to create and edit lake maps from sonar recordings you make on some Humminbird units.
AutoChart Pro has a few more features than AutoChart.
A Zero Line Card comes packaged with each of these software packages.  You must load your AutoChart created maps onto the Zero Line Card which is then inserted into your Humminbird unit.  Without the Zero Line Card you cannot load maps created in AutoChart or Autochart Pro.
You can buy additional Zero Line Cards (about $100 us) if you need more storage for created maps.
If you do not have AutoChart or Pro the only use for a Zero Line Card would be to record AutoChart Live recordings if your unit has that feature.  In my opinion AutoChart live recordings are not all that useful on their own.
It sounds like you might need to purchase the AutoChart software (which comes with one Zero Line Card) to map your fjords.
Offline mako9man2
« Reply #2 on: March 15, 2017, 10:51:17 AM »
In the USA the list price for AutoChart is $199.99, the list for Autochart Pro is $249.99 and the list price for a Zero Line Card is $99.99.  But they can be purchased for as little as $136 for Autochart and $169 for AutoChart Pro.  Remember that with either AutoChart software purchase you get 1 Zero Line Card($99 value) so that means you are only paying $36 for the AutoChart software and $69 for AutoChart Pro
by CamoHunter
Last post April 24, 2015, 02:22:16 PM
Last post February 12, 2016, 11:16:13 PM
by afaust
Last post April 07, 2017, 11:13:44 PM
Last post July 10, 2019, 09:36:19 PM
Last post May 02, 2024, 09:02:48 AM
by Mike1966
Last post June 12, 2026, 11:08:02 PM
Last post July 25, 2026, 07:48:41 PM
