Author Topic: 1197C locked - issue  (Read 9085 times)
Offline Manuel Suarez
« on: February 25, 2015, 04:39:28 PM »
Hi all,
I have a problem with my 1197C. It was working fine for some years but last saturday when I switched on it started to work properly but after 5 seconds the sonar is absolutely locked. The only thing I can do is to switch off the power cable, all buttons are unavailable.
It occurs always since that moment. If I start in simulator everithing is ok, in system status mode,all accesories are passed. I have disconected all connectons and I have the same problem. I have reseted to defaults and it is the same, I have load again the sonnar software and it is locked after 5 seconds.
Please, help!!!
I am a Spanish angler and I hope not to send it to repair ...
Thanks in advance.
Manuel
Re: 1197C locked - issue
« Reply #1 on: February 26, 2015, 12:53:05 PM »
Manuel,
If this is happening with all of the accessories (transducer, GPS, etc.) disconnected than it is one of two things: power related or something within the 1197 unit.  Rule out power related by cross-testing units with someone else that has an 800/900/1100 series unit or try it on a new battery.  Otherwise, you will need to look at sending it into your local service center.
« Reply #2 on: February 26, 2015, 03:34:09 PM »
Thnks Greg,
I have connected to a batery but I get the same.
I have tried to upgrade the software to version 6.310 and finally it was working, but then I
have tried to upgrade to 6.600 and it didn't finish. Now the 1197C is locked in loading (first screen).
Any idea is welcome!!
Thanks in advance
« Reply #3 on: February 26, 2015, 04:25:29 PM »
You can try the boot strap method using the SD card.  Do a search on the web site as I know that there are instructions for doing this.
« Reply #4 on: February 26, 2015, 05:57:21 PM »
Here's the link to the instructions for the bootstrap method ...
http://forums.sideimagingsoft.com/index.php?topic=661.0
Last post August 24, 2010, 10:32:57 PM
by SmokinBobO
Last post February 09, 2011, 01:24:50 PM
Last post February 07, 2012, 03:48:48 PM
by nicknight
Last post April 16, 2012, 04:07:50 PM
by navionic
Last post April 30, 2012, 01:49:49 PM
Last post September 03, 2013, 11:26:03 AM
Last post October 08, 2014, 12:51:52 PM
Last post August 01, 2017, 02:47:41 PM
by Moose1am
