Author Topic: 1197C SI Bottom Lock issue with 4.950  (Read 7221 times)
Offline SmokinBobO
« on: August 23, 2010, 06:41:08 PM »
I have noticed that I am having a lot of problems maintaining a good bottom lock under 15 feet of water with my HB this year.  I don't recall if I was having the same problem with 4.750 early.  Is there a solution to this issue?
Re: 1197C SI Bottom Lock issue with 4.950
« Reply #1 on: August 23, 2010, 08:59:20 PM »
SmokinBobO,
Welcome to the forum.  You should have switchfire set to clear when in less than 15' of water and it should help.
Offline SmokinBobO
« Reply #2 on: August 24, 2010, 10:32:57 PM »
OK.  I'll give that a try.  If I set a specific lower limit, the unit displays a good bottom and water column, but if left in auto it displays multiple bottoms and depth is reported in various numbers of multiples of the actual depth.
Last post June 09, 2012, 02:45:54 AM
by mtbasser
Last post February 07, 2013, 08:44:05 AM
by gixxer01
Last post September 16, 2014, 09:56:27 AM
by Sawyer
Last post February 26, 2015, 05:57:21 PM
Last post June 25, 2015, 07:01:50 AM
by bobcoy
Last post February 09, 2017, 07:18:27 PM
Last post May 13, 2018, 10:41:56 AM
by Sigler
Last post June 11, 2019, 10:46:10 AM
by ezfishn
