Author Topic: AutoChart Tutorials & Manuals  (Read 49061 times)
0 Members and 7 Guests are viewing this topic.
Offline CamoHunter
  • Unit(s): 1199ci HD SI, 788ci HD, 788ci HD
  • Accessories: AutoChart Pro, Terrova 80 - iPilot Link
« on: February 25, 2015, 10:26:39 AM »
Humminbird Tutorials
Here are several step-by-step tutorials I put together to hopefully help with learning the program.
Autochart: How to Make Sonar Recordings on your Humminbird
Autochart: How to Save and Export Humminbird Tracks on Your Humminbird Unit
AutoChart Tutorials
Autochart: How to Import Data & Create a Map
Autochart Tutorial: How to Remove/Edit Bad Data Points
Autochart Tutorial: How to Create Custom Shoreline Data (From Humminbird website)
AutoChart: How to Create a Custom Shoreline (Step-by-Step)
AutoChart: How to Delete Your Map and Start Over
AUTOCHART MANUALS
Here are several AutoChart manuals which were published by Humminbird.
AutoChart - Software Installation Guide
Instructions on how to install the AutoChart PC Software.
AutoChart - Getting Started Guide
This is sort of a quick-start guide. Helpful to go through the tutorial steps to get started.
Installation & Operations Guide (AutoChart - Installation and Operations Guide)
This is the primary manual for AutoChart. It goes more in depth into functions and features of the program.
ZeroLines SD Card - Manual for Using in Your Depthfinder
This is a manual that contains information about changes you can make on your ZeroLines custom map, on AutoChart compatible Humminbird units.
ZeroLines SD Card - ONIX & Ion Manual
This is a manual for those of you with a Humminbird ONIX or Ion, and contains information on the additional features of those units.
ZeroLines SD Card - Warning, Do Not Delete Folders
Just a fair warning, do not delete the LkMaster, AC, or SI folders on the ZeroLines SD Card.
You can download/print any of these help guides by clicking the Download icon at the top of the linked website.
« Last Edit: February 25, 2015, 10:28:19 AM by CamoHunter »
Offline JoeyWelch
  • Unit(s): 899ci
Re: AutoChart Tutorials & Manuals
« Reply #1 on: February 25, 2015, 10:53:37 AM »
Like This! ;D
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: February 25, 2015, 11:50:25 AM »
What a great idea. Thank you.
Offline Bubba Canuck
  • Unit(s): 1199ci HD SI / 999ci HD SI / 597ci HD DI
« Reply #3 on: June 10, 2015, 07:53:29 PM »
I finally went through all of these tutorials. Excellent job! Thank you.
14' Lund "Tin Can", 25 hp Merc: $3,000
Humminbird 1199 CI HD SI Combo, Minnokota Terrova with iPilot Link and AutoChart Pro: $5,000
Humminbird 597 CI HD DI Combo: $600
Reaction from other Boats when Fishing: PRICELESS
Offline coy
  • Unit(s): HELIX 5 SI GPS, HELIX 5 DI
  • Software: Default
  • Accessories: Default
« Reply #4 on: December 26, 2015, 10:45:57 PM »
Thank you for this information.  Your work is greatly appreciated!
Offline mcjsarf1
  • Unit(s): 999,987,997,698,597,385
« Reply #5 on: May 09, 2016, 04:52:08 PM »
Your presentation is a gift from God!  You made it so easy for an old dog to learn these new tricks!!
havelangler
  • Guest
« Reply #6 on: August 23, 2017, 02:32:59 PM »
Thanks !!!
The tutorial "How to Delete Your Map to Start Over" was very helpful for me.
Greetings from Germany,
havelangler
Offline antanase
  • Unit(s): 1197, 798
  • Software: 6.640, 6.35
  • Accessories: WeatherSense, GPS, MK PowerDrive V2
« Reply #7 on: May 15, 2019, 06:01:45 AM »
Hello,
There are many shallow lakes in my area (2-6 ft). Which transducer settings do you use? How close to one another should my grid passes be? Geometry says that, in 5 ft water, using the 200 kHz beam, the width of the sonar reading is 3 ft, while using the 83 kHz beam, the width is 16 ft.
I use a 1197c SI.
Best regards,
Andrei
Offline outdoorguy
  • Unit(s): 1198 , 997c SI
  • Software: 457.0
« Reply #8 on: December 13, 2019, 07:36:19 PM »
Long time HB user. Owned nearly everything made by HB. Currently using 3  Helix units.  Looking to add Autochart Pro BUT, need to be able to export AC maps for printing. Does anyone know if it is possible?
Offline GordF
  • Unit(s): Helix 10 GN2 GPS Chirp X Helix 9 GN2
  • Software: 2.280
  • Accessories: GPS Puck
« Reply #9 on: October 23, 2020, 04:00:43 PM »
[ Attachment Invalid Or Does Not Exist ] Instead of deleting the LkMaster Lake file can you just take it off and save it?
« Last Edit: October 23, 2020, 07:24:05 PM by GordF »
« Reply #10 on: October 23, 2020, 11:40:07 PM »
If no one pops in with AutoChart experience to help with your question - Humminbird may be able to help  ...
1-800-633-1468
Offline GordF
  • Software: 2.280
« Reply #11 on: October 24, 2020, 02:38:33 PM »
Ok ty. Yes I see that @CamoHunter hasn’t been active since 2017.
Offline Kees Michielsen
  • Boston Whaler Montauk fanatic
  • Unit(s): Helix9 G4N / HB998cx Si
  • Accessories: Autochart pro
« Reply #12 on: December 07, 2020, 10:27:31 AM »
Just installed Autochart Pro on the PC.
Tested a few files on the pc.
How do I get a clear workspace again? All the imported data stays on the screen as green boxes. Removed the program and reinstalled but still tehe data is on the screen, any help please?
Offline D S
  • Software: 7.5
« Reply #13 on: December 10, 2020, 10:00:47 AM »
see above....... caomhunter tutorial how to delete a map and start over
stgr
Offline GordF
  • Software: 2.280
« Reply #14 on: December 10, 2020, 11:03:15 AM »
Open the Chart Index File by pressing B on your keyboard. Open Default. Select all the files and remove them. Go to file menu and look for Reload active chart and you’re good to go.
« Reply #15 on: December 11, 2020, 05:50:42 AM »
@GordF,
Thank you very much for your help, this is what I was looking for  :)
Last post February 14, 2010, 02:23:32 PM
Last post March 27, 2010, 11:57:28 AM
Last post March 17, 2011, 01:11:21 PM
Last post March 18, 2011, 10:03:53 AM
Last post January 03, 2013, 06:09:12 PM
by Jim Jack
Last post August 14, 2014, 03:54:13 PM
by Beaulieu80
Last post July 11, 2014, 08:21:41 PM
by JR123
Last post September 27, 2014, 04:50:16 PM
by jimham82
