Author Topic: 798ci si combo  (Read 7506 times)
Offline richteb
  • Unit(s): 798ci si
  • Software: 6.3
  • Accessories: none
798ci si combo
« on: February 17, 2015, 06:40:06 PM »
Does anyone know how to move the cursor between say chary and side imaging when the screen is in split view? Example chart on top and side imaging below and want to create waypoint on side imaging without changing the view. On my unit the default cursor position when I use the four way toggle is on the chart.
Re: 798ci si combo
« Reply #1 on: February 18, 2015, 12:10:05 AM »
I can't find in the 798 manual where there is an "Active Side" that is selectable on a Combo view (like on the 800/900/1100 series units)...
You can set the full screen SI as one of the 3 presets to easily get from the Chart/SI Combo view to the full screen SI view to mark a waypoint on the SI image ...
Greg or one of the 798 users may have more info when they check in ...
Re: 798ci si combo
« Reply #2 on: February 19, 2015, 03:07:58 PM »
richteb,
You can’t do this in the 798 units when using a Chart split View.  If you notice that when you move the cursor that the cursor is not really moving but that the background map is moving.  So you can’t scroll to the edge of the Chart window and onto the Side Imaging window like you can on some sonar combo Views.  There are no menus for these Views to allow this either.
Last post September 05, 2011, 09:38:50 PM
by Roddy
Last post December 07, 2011, 12:22:56 PM
Last post June 23, 2012, 08:37:32 AM
Last post April 16, 2013, 04:37:15 PM
by Kim Christiansen
Last post April 28, 2015, 10:17:09 PM
by FishSeeker
Last post April 29, 2015, 12:45:58 AM
Last post August 05, 2015, 10:06:41 PM
by alwayslearn
Last post October 03, 2015, 03:17:04 PM
