Author Topic: 798CI SI HD COMBO  (Read 11680 times)
Offline NITRO898
  • Unit(s): 1197C SI - 798ci si HD
  • Software: 5.500 5.590
  • Accessories: AS SI DB Y, ETHERNET & XP 9 20
798CI SI HD COMBO
« on: September 04, 2011, 06:11:10 AM »
I need to replace my xtm  9 si 180 t . Is there any advantage in replacing it with the xtm 9 hdsi 180 t  transducer? thanks ,Earl
Offline Wingnutt
  • Unit(s): 798CI HD SI
Re: 798CI SI HD COMBO
« Reply #1 on: September 04, 2011, 07:42:28 AM »
I'm not an expert so I'm sure others will chime in....
You will get a slightly better picture with the High Def one, but not as good a picture as if your unit were equipped with the ability to process the 800kHz signal.  At least that's the way it is if with the non-trolling transducers.  I would guess that they both have sufficient shielding for RF since both are designed to be on a trolling motor.
Offline NickO
  • Unit(s): 898c SI, 998CI HD SI
  • Software: 6.740, 6.740
  • Accessories: Ethernet
« Reply #2 on: September 04, 2011, 01:20:40 PM »
Nitro,
I've got both transducers for my 798 HDSI.  The "xtm 9 hdsi 180 t" definitely produces much crisper screens across the board. It's worth it.
I can also see the diff in the 3rd party viewers.
« Last Edit: September 04, 2011, 01:21:52 PM by nicko »
Gee that broke easy.
Offline NITRO898
« Reply #3 on: September 05, 2011, 09:33:24 AM »
Do ya think its worth the extra 300 bucks? Thats with a transducer shield and saver too for the hdsi transducer on the TM. PS, happy labor day!
Offline Roddy
  • Scan,scan and rescan
« Reply #4 on: September 05, 2011, 09:38:50 PM »
Nitro; They can be found for less than $200.00 some times $175.00 on the www. Just saw one on ebay for 119.00.  Roddy
« Last Edit: September 05, 2011, 09:45:30 PM by Roddy »
Scan,Scan and Rescan Roddy
Last post December 07, 2011, 12:22:56 PM
Last post July 11, 2012, 04:54:29 PM
by Speedtroller
Last post June 23, 2012, 08:37:32 AM
Last post February 01, 2013, 09:21:21 AM
Last post March 21, 2013, 01:44:46 PM
Last post August 26, 2013, 07:35:00 AM
by Dirty Birch
Last post November 28, 2014, 07:54:33 AM
