Author Topic: Extending transducer cable  (Read 13439 times)
Offline pentlanddiver
  • Unit(s): Hummingbird 798ci HD
« on: February 07, 2015, 02:45:35 PM »
I'm planning to mount the 798ci transducer on a 'keel' mounted below the towfish of a magnetometer. The towfish and transducer will be about 25m behind the towing boat at a depth of about 10m.
I've read the many posts about cables but I'm still confused enough that I'm not sure what to buy. The transducer cable has 2 screened twisted pairs inside an overall screen. Each screen has a multistrand drain wire running within it.
I need to add about 30m of cable to the transducer.
Has anyone extended a 798ci transducer cable by about 30m and if so what cable have you used. Are the screen drains really important?
Re: Extending transducer cable
« Reply #1 on: February 07, 2015, 03:35:03 PM »
I know Lowrance makes cable extenders. Check with Hb customer service and ask them...Chuck
Offline navionic
« Reply #2 on: February 07, 2015, 03:43:19 PM »
http://www.humminbird.com/Products/EC-W30/
maximum 10m
« Reply #3 on: February 07, 2015, 05:40:47 PM »
Thanx for the info guys. Will check it out.
Maurice
Offline Rüdiger
« Reply #4 on: February 08, 2015, 04:08:43 AM »
Hi Maurice
I use 3 10m extensioncable for my towfish and it works.
mvh
Rüdiger
Finding is better than losing
Offline DiveExplorer
« Reply #5 on: March 13, 2015, 03:50:18 PM »
When you use that many extensions cables, like 3 of them, do you need to put the sensitivity higher ?
Offline Rüdiger
« Reply #6 on: March 14, 2015, 03:37:39 AM »
Hi DiveExplorer
No, no changes to the settings.
mvh
Rüdiger
« Reply #7 on: March 14, 2015, 10:27:53 AM »
Ok thats cool.  :)
by Rickard
Last post April 09, 2012, 05:18:50 PM
Last post January 23, 2013, 05:13:42 AM
by hvychev77
Last post January 05, 2014, 10:56:35 AM
by Dieago
by bobcoy
Last post June 17, 2014, 08:44:31 PM
by sblatt
Last post March 19, 2016, 05:16:42 PM
by Rickard
