Author Topic: Transducer cable  (Read 13313 times)
Offline jorawil
  • Unit(s): 898c SI
Transducer cable
« on: January 06, 2012, 10:46:26 PM »
I have a 898 SI/DI unit. My cable for the transducer got pinched and cut some of the wires. Can these wires be spliced back togeather and will the unit work? This section of tht cable will not be in the water.
Thanks,
jorawil
Offline offroad
  • Unit(s): 1197/ 898
Re: Transducer cable
« Reply #1 on: January 07, 2012, 12:07:19 AM »
Yes  no problem  did the same thing and joined it back together... l soldered the wires then put heat shrink on them used tape on top
« Reply #2 on: January 07, 2012, 05:04:28 PM »
I forget where it is on this forum but Jolly Roger had a post last year on cable splicing. Good pictures. Maybe you can search better than I.
Offline jorawil
  • Unit(s): 898c SI
« Reply #3 on: January 08, 2012, 12:31:42 AM »
Thanks for the replies. I will try fixing them myself.
jorawil
« Reply #4 on: January 16, 2012, 01:21:44 PM »
Make sure and replace and reconnect the foil shielding as well.
Offline jorawil
  • Unit(s): 898c SI
« Reply #5 on: January 16, 2012, 05:46:25 PM »
Thanks for the info.
jorawil
« Reply #6 on: January 16, 2012, 06:11:11 PM »
The foil shields are part of the attempt to prevent crosstalk between pairs of wire carrying current and causing interference.
Just the way these new very low amp current technological devices work. Not only sonar but other electeronics, like computers..
Last post April 27, 2009, 10:16:31 PM
by Rickard
Last post June 23, 2010, 06:00:18 PM
Last post December 25, 2010, 10:00:25 AM
Last post July 13, 2013, 06:51:56 AM
Last post April 09, 2012, 05:18:50 PM
Last post September 11, 2012, 07:30:05 AM
by gros21
by bobcoy
