Author Topic: 798ci si transducer  (Read 8175 times)
Offline richteb
  • Unit(s): 798ci si
  • Software: 6.3
  • Accessories: none
798ci si transducer
« on: February 06, 2015, 11:38:08 PM »
Hi guys,
Hoping for some clarification on transducers for my 798ci si combo unit. Will the xhs 9 hdsi 180 t work on my unit? if not then what would be a better transducer then the one that was included. Hoping to improve the quality of the images that I am getting.
Re: 798ci si transducer
« Reply #1 on: February 07, 2015, 08:51:57 PM »
The XHS 9 HDSI 180 T can be used on the 798 for somewhat better SI images ...
This is due to the longer SI piezoes in the XHS 9 HDSI 180 T ... Longer piezoes create a thinner beam ...which renders better detail ...
The XHS 9 HDSI 180 T will also function at 800kHz ... But your 798 will not be able to utilize this 800kHz frequency because the 798 will not transmit the 800kHz frequency ...
There are several that say the added detail in the 455kHz SI frequency from the longer SI piezoes in the XHS 9 HDSI 180 T are worth the upgrade ...
« Last Edit: February 07, 2015, 08:53:13 PM by rnvinc »
Offline hookbender
  • Unit(s): 798ci HD SI, 798ci HD SI
  • Software: 7.120
  • Accessories: Interlink, AS-GR50
« Reply #2 on: February 17, 2015, 11:18:39 AM »
I have the compact transducer on the 798 in the front and the XHS 9 HDSI 180 T on the 798 in the dash. The images seem a little more detailed on the dash unit, but the compact transducer is mounted on the trolling motor. I have not had a chance to record the same object from both to compare yet, but I will and compare them on Hummviewer. I have no regrets about using the larger transducer. In reality I think the real difference is seen on the larger screens.
Offline richteb
  • Unit(s): 798ci si
  • Software: 6.3
  • Accessories: none
« Reply #3 on: February 17, 2015, 06:33:12 PM »
Thanks guys for your input. I have one on order.
Last post October 20, 2009, 09:00:54 AM
Last post February 08, 2011, 05:53:53 AM
by SaminVa.
Last post February 02, 2012, 10:25:51 AM
Last post August 09, 2012, 01:39:03 PM
Last post May 20, 2013, 12:38:12 PM
Last post April 13, 2014, 11:25:37 PM
Last post June 27, 2014, 10:26:23 PM
by ice
Last post January 10, 2015, 02:29:45 PM
by born 2 fish
